how to check for spark and fuel pressure
Old Apr 15, 2005 | 11:57 AM
yellowmonkeyboy's Avatar
Default how to check for spark and fuel pressure
how do you check that youa re getting a spark
and how do you check for fuel pressure?
Old Apr 15, 2005 | 11:59 AM
civiccpedx's Avatar
Default Re: how to check for spark and fuel pressure (yellowmonkeyboy)
well you can check for spark by pulling a spark plug, put it back in the wire, hold it to the valve cover and see if you can see a little spark when someone turns the engine over.(do with #1 spark plug)
the fuel, you can check if you turn the key to the on position you should hear a noticable noise, when the check engine light comes on, that is the fuel pump priming. when the check engine light goes off, the sound should end.
Old Apr 15, 2005 | 01:36 PM
.Kevin.'s Avatar
there should also be a thing that looks kinda like a tire valve with a cap like a tire valve and just push it down that will tell you if u have fuel pressure
Old Apr 15, 2005 | 01:58 PM
Default Re: how to check for spark and fuel pressure (Slow_CvC99)
this tire valve looking thing, where is it located? or do you happen to have a picture.. thanks for thelp you guys, my car just shut off while i was driving and wont turn back on so i am trying to pin point the problem
Jabinya
Jul 13, 2007 05:49 AM
czer47
Jun 28, 2007 10:49 PM
BoostFrenzy.com
Jan 8, 2006 04:24 PM
rex_racer728
Jun 26, 2005 11:57 AM
Hondasaurs
Nov 2, 2002 07:21 AM
