got a contest of sorts......... who can weld aluminum foil?
im just curious as to who on here can weld together 2 pieces of aluminum foil........ and if you dont think its possible i know it is..... my gran-dad, who died a couple years ago, could do this and used to win bets at work all the time betting people he could do it...... otherwise i would show you a pic of it.... he was a fabricator his whole life so he was VERY good at welding
i have no clue how to use the tig we have as he never tought me so i cant even try lol
anyways if any of you can do it post up some pics
i dont have a prize or anything
just bored and curious to see some of you guys skills
--chris
just bored and curious to see some of you guys skills--chris
I'll give it a go later tonight or tomorrow, just got to go buy the foil.
I've done .020, so hey, .005 should be a snap
Oh, and teach yourself, I did. Just pick up some scrap and the torch and make it hot.
One of the people I went to school with used to weld razor blades together...tin foil might be pushing it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goullish »</TD></TR><TR><TD CLASS="quote">I'll give it a go later tonight or tomorrow, just got to go buy the foil.
Oh, and teach yourself, I did. Just pick up some scrap and the torch and make it hot.</TD></TR></TABLE>
haha ok im interested to see how this comes out........ and as far as teaching myself i would have no clue where to even start with the welder. ive got the mig down but have no clue where to start with the tig its got everything there..... tons of rods, pedal, gun, etc......... but i do know that its out of gas i will need to get it filled before i do anything
fill it with gas and just start using it. it will all make sense once you put it into practice. tig scared the crap out of me for about 1 min until i pushed the pedel down and formed my first puddle.
Guest
Posts: n/a
There is special welding machines for that kind of thing.Like mold repair and aircraft parts.The highest amps is 75 and goes down to .5 amps.And you have to use .40 or .60 tungsten.The ,40 is so small that you can't sharpen it.There is this
stuff that you dip the tip in when it is hot and that sharpens it.And when you start ,start on another piece of metal to get the tungsten hot then move over to
your work and it starts lower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF »</TD></TR><TR><TD CLASS="quote">There is this
stuff that you dip the tip in when it is hot and that sharpens it.</TD></TR></TABLE>
Chem-sharp, I think it's called.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF »</TD></TR><TR><TD CLASS="quote">The ,40 is so small that you can't sharpen it.There is this
i never knew this... u cant sharpen .40 with a grinding wheel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t »</TD></TR><TR><TD CLASS="quote">
i never knew this... u cant sharpen .40 with a grinding wheel?</TD></TR></TABLE>
I think there might be some zeros missing, since I've never seen a half-inch tungsten.
Guest
Posts: n/a
They don't weld allum.foil together and they haven't for a long *** time.There is a machine that fuses it together.And when they did weld it together it was about .015 to .020 thick and they backed it up with a big *** heat sink.
And I will bet you a million dollars you can't solder it .Because you can not solder allum.But you can try if you want.Some times this Text **** sucks.Because
you can't tell if I'm being a smart *** or not.Well I'm not. LOL . See
Well boys and girls, after much error, I successfully tackled the foil for exactly one quarter of an inch.
I did cheat...slightly. I consider it bending the rules. I had to fold it. I tried it unfolded at first, and even the slightest arc would splatter a hole the size of a dime.
Picture (of very poor quality) can be found here -
http://www.we-todd-did-racing....D.jpg
civic2nr9177
Welding / Fabrication
32
Jan 22, 2009 10:05 PM
Pay2play killa
269
Dec 11, 2008 07:13 PM
mstewar
Apr 13, 2006 09:40 AM
