Kinda lost on this one guys
Old Apr 15, 2005 | 07:18 AM
Evil-EK's Avatar
Default Kinda lost on this one guys
A buddy of mine put a obd2b to obd1 conversion harness in his 2000 si. The car runs but when it gets up to normal temp the cel comes on. It is throwing a code 43 (fuel supply). I have tried resetting the ecu and have checked for other fuel related issues but I find nothing. Got any ideas?
Old Apr 15, 2005 | 07:32 AM
Ministry's Avatar
Default Re: Kinda lost on this one guys (BigBlockH22atch)
I would check the injectors, fuel filter, fuel pump, fuel lines.
this didn't happen until he switched to OBDI ecu?
Old Apr 15, 2005 | 07:45 AM
Evil-EK's Avatar
Default Re: Kinda lost on this one guys (dreamer)
No he had a cel for secondary o2 and decided to just convert the car to obd1 to eliminate the secondary o2. I donated the p28 and he bought the harness. I have checked all the above but the filter. My turbo ls/vtec threw this code and it was the primary o2 going bad that caused it.
Old Apr 15, 2005 | 07:51 AM
shifty35's Avatar
This is just a stock P28, or a chipped one? What program/settings? Do you have a copy of the bin?
Could be the program is running really lean/rich at idle, making the computer think something is up with the fuel system.
Ministry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch &raquo;</TD></TR><TR><TD CLASS="quote">My turbo ls/vtec threw this code and it was the primary o2 going bad that caused it.</TD></TR></TABLE>
well have ya checked that? I kinda doubt a clogged fuel filter would cause your ecu to throw a code
Old Apr 15, 2005 | 09:51 AM
Evil-EK's Avatar
na it is a stock p28. and I dont think the o2 is causing it. the car only has like 43k miles on it.
Old Apr 15, 2005 | 10:15 AM
IHateJDM's Avatar
friend of mine just had that code (64K miles on his) and his o2 was the cause. He was throwing a code for o2 also though. Is the Fuel system code your only cel?
Old Apr 19, 2005 | 08:17 AM
Evil-EK's Avatar
Default Re: Kinda lost on this one guys (IHateJDM)
Yes the fuel system code is the only one.
Old Apr 19, 2005 | 08:20 AM
IHateJDM's Avatar
does your gas cap seal the tank correctly?
Old Apr 19, 2005 | 08:33 AM
Evil-EK's Avatar
That is a new idea. I totaly over looked that. I will check it and see. Thanks guys.
Old Apr 19, 2005 | 09:06 AM
thehatchninja's Avatar
maybe you should chip it for b16, it will never run right if you don't, even if it isn't throwing codes.
Old Apr 19, 2005 | 09:09 AM
mwieczorek43's Avatar
Default Re: (thehatchninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">maybe you should chip it for b16, it will never run right if you don't, even if it isn't throwing codes.</TD></TR></TABLE>
I agree with what he said. Anything worth doing, is worth doing right.
Old Apr 19, 2005 | 09:16 AM
pdiggitydogg's Avatar
The problem is probably because its running the d16z6 program for a b16a2.
It needs to be chipped to simulate the p30
SmaTTeRLegion
May 29, 2013 07:36 PM
Skip01
Jun 20, 2009 09:22 PM
teg_racer
Dec 11, 2007 09:46 PM
DualCamEK
10
Dec 25, 2004 08:01 AM
shivic
Apr 23, 2004 11:20 AM
