b18 or b20 ls vtec or b20vtec i have all the parts which one to choose
here is the deal i have the option of building two motors
the problems reliability "i am tired of replacing motors" !!!!!!!!!
octane of gas, is 12.5 comp to high for street driven
i have all the necessary parts to build the short blocks
first option b20:::::::::::::
84.5 mm bore, knife edged crank, forged i beam rods 12.5 compression cp pistons
or or
LS block ls rods with arp bolts and used b16 pr3 pistons same crank as above
after seeing the recent ls vtec builds on HT making over 200 whp on pump gas street driven is making me lean towards lsvtec
how much more potential do i have with the b20 over the ls?
or should i build the b20 and when it blows use the b18 as back up
or or
well 12.5:1 is to much for compression. 11.5:1 should be your max as far as keeping it reliable. knife edged crank is not good for reliability... and you say you want to use used pr3 pistons? this means that you want to use piston that are almost 15 years old... not smart. you need to do alittle bit more research.
sell all the stuff you have and buy a low mileage gsr engine and buy bolt ons and cams and have some head work done. and engine management and tuning...... bam almost 200 whp and decent reliablity.
i'd say it's all on how high you wanna rev.
i'd say stay w/ the b20 block first, but make sure you get cams that will make power in the lower rpm's and not rev to high, because of the stock b20 sleeves
cam selection would be bc3+ or bc4's
the torque from a 2.0 l is awesome but people often over rev this sucker like krazy.
if you want pretty good reliability i would go w/ ls/vtec
ls block
ls crankshaft
ls rods (shot peened)
arp rod bolts
pr3 pistons or p30 BRAND NEW (don't skimp on the bottom end)
balance entire bottom end
vtec head ported n polished
ctr cams
aebs manifold (if b16 head is used)
65mm tb
a good header: dtr/smsp/hytech
a b16 tranny or type r tranny
p28 obd1 hondata
oem reliability that you will see power
ls block
ls crankshaft
arp rod bolts
ctr cams
65mm tb
p28 obd1 hondata
Well i do agree with pr0honda on the part of selling both and buying a gsr. I would sell both blocks and buy a gsr block... but then again i am ahuge PMR supporter.
as for you question.. i would go with the b20 over the ls. I dont feel like the difference in the reliability factor is going to be all the large. Plus since you have the ls block already, just keep it for back up.
Also, even though a few ls-vtecs have been making over 200 lately, it also seems as if B20s with a simular head package is making around 220...
yeah 220+ whp is my goal
i already have a fully built head, just need to get the right cams
thinking about skunk stage2 clones
what do you think?
where can i get some new ones cheap?
what do you think?
both will yield the same thing if you bore them out to 84.5mm or so...
I have a set of pistons if you are intrested. Perfect for an all motor setup.
https://honda-tech.com/zerothread?id=1231205
I only got 236hp and 171tq out of my set up.
97 B20b JDM Block
12:5:1 Wiseco pistons
Eagle Rods
ACL bearings
Mirco Polished GSR Oil Pump
Knife Edge Crank
Balanced & Blue Printed
GSR Pan & Pick up
ARP head studs & rod bolts
99 B16a2 Head
Full Port and Polish
7 Angle Valve Job
Crower 1mm Oversize Valves
Crower Springs & Retainers
Skunk2 Stage 1 cams
AEM- Cam Gears, Fuel Rail, FPR
STR cam Seals
Full MSD
DC Sports 4-1 header
AEBS Intake --Polished
Holly 70mm Tb
J's Racing Air Intake
Rc 310cc
Hondata Intake Gaskett
Hondata S200
Custom EBP Valve cover / Cut for cam gears
97 GSR Tranny
ACT---HD PP, SS disc, 7lb flywheel
GSR axels
97 B20b JDM Block
Eagle Rods
ACL bearings
Knife Edge Crank
GSR Pan & Pick up
99 B16a2 Head
7 Angle Valve Job
Skunk2 Stage 1 cams
STR cam Seals
Full MSD
Holly 70mm Tb
Rc 310cc
Hondata S200
97 GSR Tranny
GSR axels
I dunno if this is what you meant quick1racer but i would take the b16 haed and throw it on the b20.. more displacement then the ls and 12.5 CR is kinda high but you should be fine.. do some crank work and dont rev crazy and youll have yourself a nice setup
vtecmissle
Oct 26, 2005 02:26 PM
