d15b ecu
Old Apr 14, 2005 | 05:15 PM
b20vtechatch
Guest
Posts: n/a
Default d15b wiring harness
will a p2p ecu work on a d15b motor
Modified by b20vtechatch at 12:02 PM 4/18/2005
Old Apr 14, 2005 | 05:32 PM
slotec's Avatar
Default Re: d15b ecu (b20vtechatch)
its obd2 and d15b is obd1 jus get the ecu meant for it the p08 or just a p28
Old Apr 14, 2005 | 06:29 PM
BauleyCivic's Avatar
Risky Business
Default Re: d15b ecu (slotec)
Depends on what car its going in...
Old Apr 14, 2005 | 07:32 PM
slotec's Avatar
Default Re: d15b ecu (BauleyCivic)
this is also true but stock the plugs off the injectors and sensors are obd1
Old Apr 14, 2005 | 07:33 PM
DJ_SaNdOz's Avatar
If you convert the motor to run OBD2 I would imagine it would work.
Old Apr 15, 2005 | 06:32 AM
b20vtechatch
Guest
Posts: n/a
Default Re: d15b ecu (DJ_SaNdOz)
how much for a p08 its an obd1 jdm d15b
so which one p08 p28 or p30
Old Apr 15, 2005 | 07:13 AM
ABK's Avatar
ABK
you can use p08 or p28 or any obd I ecu that has been chipped for that engine
if the car is obd II with JDM d15b then use p2p, or get a jumper harness and then you can use a obd I ecu.
Old Apr 15, 2005 | 07:55 AM
b20vtechatch
Guest
Posts: n/a
Default Re: d15b ecu (ABK)
the car is an eg6 obd1 and the engine is a d15b jdm obd1. wont a p08 work perfectly fine?
Old Apr 15, 2005 | 08:28 AM
95jeremie's Avatar
i have a d15b in my 95 ex (obd1) and I'm useing the original ecu i think it's a p28 and it works fine
Old Apr 15, 2005 | 09:11 AM
DJ_SaNdOz's Avatar
a P08 will work perfectly fine, but it uses a different O2 than the P28 would.
Old Apr 15, 2005 | 06:43 PM
ABK's Avatar
ABK
yeah p08 will use a single wire, and p28 will require a 4 wire O2.
Old Apr 15, 2005 | 08:23 PM
slotec's Avatar
wrong the p08 does use 1 wire o2 but it doesnt throw any type of codes on a dx/ex obd1 eg. i have one in my car, i like it alot better than the p28 and a p30 is a b16 ecu
Old Apr 17, 2005 | 10:05 AM
b20vtechatch
Guest
Posts: n/a
so i should just get a p08 than. will it hook right up to my car? 93 honda civic vx.
Old Apr 17, 2005 | 05:08 PM
slotec's Avatar
yepp direct plug and play
Old Apr 18, 2005 | 10:40 AM
b20vtechatch
Guest
Posts: n/a
my motor came in today and the wiring was cut. my friends got another eg6 with a perfect wiring harness. only one main harness was cut. will it work fine? his car is a 93 its a d15b usdm its vtec but its not the jdm one. can i just butt connnect all of them. and will the shift linkage work off that too. and all the motor mounts?
my engine is the d15b jdm.
Modified by b20vtechatch at 11:51 AM 4/18/2005
Old Apr 18, 2005 | 11:03 AM
b20vtechatch
Guest
Posts: n/a
Old Apr 19, 2005 | 11:58 AM
b20vtechatch
Guest
Posts: n/a
Old Apr 19, 2005 | 12:07 PM
DJ_SaNdOz's Avatar
since your car is an eg (OBD1) just use the stock harness that is already in the car & run the VTEC wires. The Japanese one wouldn't work anyhow since it's for RHD
Old Apr 19, 2005 | 05:15 PM
b20vtechatch
Guest
Posts: n/a
my car is obd1. the d15b is obd1 too, but the harness was cut. Can i use the harness from my friends car who also has an 0bd1 vtec hatch, only his is usdm and the motor that i bought is a j-spec? will his harness still work on my jspec engine?
Modified by b20vtechatch at 7:09 PM 4/19/2005
Old Apr 19, 2005 | 06:29 PM
b20vtechatch
Guest
Posts: n/a
anyone know
Old Apr 19, 2005 | 07:05 PM
Otherguy's Avatar
NASIOC.com
Yes that harness will work... you should buy my jdm ecu that goes with that motor =D
Old Apr 21, 2005 | 12:52 PM
b20vtechatch
Guest
Posts: n/a
Default Re: d15b ecu (Otherguy)
i just bought one a p08
the_wholesaler
Apr 8, 2014 11:26 AM
BlueRex1020
Mar 4, 2007 12:41 PM
cyrock
Jun 25, 2006 01:29 AM
THC07
Nov 10, 2005 10:18 PM
Euro98ITR
Feb 7, 2005 01:04 PM
