VAFC wiring (stupid question)
Old Jan 29, 2002 | 07:28 PM
IntegraGSR2000's Avatar
Default VAFC wiring (stupid question)
I'm converting to a reprogramed P28 (92-95 Civic EX/SI). Should I use the ECU wiring diagram for the 25-95 Civic or should I use the diagram for the 00+ Integra GSR. Any help is greatly appreciated!
P.S. anybody do this with a P28 and 2000 GSR? Any problems (CEL or other)
Old Jan 29, 2002 | 08:19 PM
Big Teggie's Avatar
Default Re: VAFC wiring (IntegraGSR2000)
it just depends on near what plugs you are gonna tap into near. if you are running an obd2 to obd1 harness you can do it before the obd1 plugs or before the obd2 plugs. it really doesnt matter. it will work fine no matter which way, and no one really ever gets a cel from a vafc install.
Old Jan 29, 2002 | 09:00 PM
Default Re: VAFC wiring (Big Teggie)
Big Teggie,
I thought it did matter because the pinouts are different on the P28 compared with my stock ECU. Unless you're saying I use the new harness in conjuction (daisy chained) with my stock harness? Is this the case...Do I still retain use of my stock harness?
Old Jan 30, 2002 | 08:34 AM
Big Teggie's Avatar
some pinouts are different but you wont be using them. The vtec, pressure, ground power, etc. is all the same on a p28 and p72.
blacc_ej1
Jun 7, 2009 08:19 PM
itr1244
May 26, 2005 03:29 PM
EJ8Joel
Aug 1, 2003 05:25 PM
Ferrell
Jul 4, 2003 10:42 AM
SuperSteve
Jan 19, 2002 11:20 AM
