head gasket question....which to use on 81.5mm bore?
Old Apr 14, 2005 | 01:49 PM
Bigjussin's Avatar
Default head gasket question....which to use on 81.5mm bore?
Can i get away with an oem gsr head gasket? or should i go with an overbore from like cometic or someone else?
thanks in advance
Old Apr 14, 2005 | 01:50 PM
2k.civic.si's Avatar
Default Re: head gasket question....which to use on 81.5mm bore? (Bigjussin)
golden eagle
Old Apr 14, 2005 | 01:55 PM
butters's Avatar
Default Re: head gasket question....which to use on 81.5mm bore? (2k.civic.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">golden eagle</TD></TR></TABLE>
yup, im using one
Old Apr 14, 2005 | 02:08 PM
Bigjussin's Avatar
Default Re: head gasket question....which to use on 81.5mm bore? (butters)
where u get them? did u buy it alone or in the ls/vtec kit?
Old Apr 14, 2005 | 02:20 PM
Bigjussin's Avatar
they only offer 81mm or 82mm...i hav heard the stock bore can handle it...the piston dome doesnt go all the way to the houtside of the piston, allowing for some clearance...anyone?
Old Apr 14, 2005 | 02:23 PM
JSpin's Avatar
stock head gasket will be fine
Old Apr 14, 2005 | 05:08 PM
rjay8604's Avatar
Default Re: head gasket question....which to use on 81.5mm bore? (JSpin)
I have also read many time that stock will suffice. Also i believe they were designed to be used with rebored OEM applications.
Old Apr 14, 2005 | 09:15 PM
GUILOTINE's Avatar
Kill Gil
oem wont work for 81.5?
Old Apr 15, 2005 | 08:22 AM
Viorent Grip! EG's Avatar
Default Re: (GUILOTINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">oem wont work for 81.5?</TD></TR></TABLE>
it will....i believe they measure at 82mm......
i'm running cometic on my 81.5mm
Old Apr 15, 2005 | 09:24 AM
FairlightRacing's Avatar
So if I were to go to 81.25mm CTR pistons in my B16A1 a Cometic 81mm head gasket should be used?
Old Apr 15, 2005 | 03:46 PM
onepoint6i's Avatar
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Viorent Grip! EG &raquo;</TD></TR><TR><TD CLASS="quote">
i'm running cometic on my 81.5mm</TD></TR></TABLE>
your right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FairlightRacing &raquo;</TD></TR><TR><TD CLASS="quote">So if I were to go to 81.25mm CTR pistons in my B16A1 a Cometic 81mm head gasket should be used?</TD></TR></TABLE>
stock gasket will work fine
Old Apr 16, 2005 | 02:57 PM
Bigjussin's Avatar
Default Re: (ONEPOINT6i)
thanks all, just ordered an oem one....
Honda_Tech01
Jun 23, 2008 08:42 AM
tegdude227
Feb 16, 2007 08:55 PM
Master23
Mar 8, 2006 01:18 PM
t57b18
Jan 29, 2006 05:38 PM
topspeed86
Jan 6, 2005 05:18 PM
