Back Brake Creaking
Whenever I drive the car after a sit I hear a creaking towards the back when I brake in reverse, or just brake in general for that matter. I'm not sure it its the brakes or the frame. Maybe its just normal. I only hear it when I drive the car right after its been sitting, and then it goes away. Any ideas?
first of all it would make it easier for all of us to help you if you tell us what yr , model car you have ,i know 1 thing for sure if the noise is from the back it is not your axles assuming you got an accord you got a front wheel drive car you got no axle on the rear ...you need to raise car up and chk around to see if you find something loose , if you got rear discs do you have honda pads in aftermarket pads sometimes shift in caliper making noise
user 72830283
Jun 26, 2005 12:01 PM
jjj784
Jan 25, 2003 09:35 AM
