Oil Pump difference?
Old Apr 13, 2005 | 11:09 PM
EG6R's Avatar
Default Oil Pump question?
Im building a CRVtec engine, is there a difference between a B16 oil pump and a B20b oil pump? I plan to use a B16 oil pump assmebly for my setup.
What is the average life of an OEM oil pump? When should i replace them?
Modified by EG6R at 12:26 AM 4/14/2005
Old Apr 14, 2005 | 04:51 AM
limpy's Avatar
Default Re: Oil Pump question? (EG6R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6R &raquo;</TD></TR><TR><TD CLASS="quote">Im building a CRVtec engine, is there a difference between a B16 oil pump and a B20b oil pump? I plan to use a B16 oil pump assmebly for my setup.
Modified by EG6R at 12:26 AM 4/14/2005</TD></TR></TABLE>
use the b16 oil pump... it pushes more oil pressure than the b20 for the use of vtec.
Old Apr 14, 2005 | 07:45 AM
95lstegman's Avatar
Default Re: Oil Pump question? (limpy)
B20 oil pumps, at least the '99-'00 ones, are the same as VTEC oil pumps, and late LS oil pumps (i think 99 and up or so) are also the same as VTEC oil pumps.
Old Apr 14, 2005 | 08:21 AM
iakona's Avatar
see, now that is good to know. so a B20 or later B18B non-VTEC oil pump will work.
Old Apr 14, 2005 | 08:39 AM
95lstegman's Avatar
Default Re: (iakona)
yes. ask the dealer for 2000 gsr, itr, ls, and crv pumps. all the same. the housings are different, though, for earlier OBD-I cars, but since no B20-B/Z was sold here w/ OBD-I you're fine. pretty sure on the housings, but it's been a while.
Old Apr 14, 2005 | 06:13 PM
EG6R's Avatar
Default Re: (95lstegman)
So what happens if i use my stock b20b oil pump with my CRVtec setup? Vtec wont engage? Will it cause any probs?
Old Apr 14, 2005 | 06:59 PM
alpine_hikr's Avatar
i'm sure v-tec will engage but i might worry about lack of oil pressure if it cant keep up with high revving operation.
Old Apr 17, 2005 | 08:35 PM
EG6R's Avatar
Default Re: (alpine_hikr)
Is the B16 oil pump still different from the ITR/GSR/late ls crv oil pumps?
vtec youngter
Sep 19, 2011 04:40 AM
Markko
Feb 22, 2005 04:11 PM
highcomp
Apr 7, 2004 10:45 PM
byebye
18
Aug 27, 2003 08:21 AM
