Civic to b18 auto
I have a 93 civic DX automatic
I also have a 94 integra LS motor and automatic transmisson
The Question is: Will the motor and tranny bolt up? And will the wiring harness
plug up to the transmission with an LS aotumatic ECU?
Has anyone ever done this swap? I might as well convert the car to MT if there is transmission wiring involved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2001 »</TD></TR><TR><TD CLASS="quote">I have a 93 civic DX automatic
Has anyone ever done this swap? I might as well convert the car to MT if there is transmission wiring involved.</TD></TR></TABLE>
You might as well convert the car to MT... PERIOD.
youll prolly need the motor and tranny mount off the teg motor for proper install
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaMyth »</TD></TR><TR><TD CLASS="quote">what kind of tranny do I need </TD></TR></TABLE>
youll need a tranny from any b-series 94-up, hydrolic 5 speed if your car is 5 speed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deLasoL7 »</TD></TR><TR><TD CLASS="quote">if you're planning to really go fast... keep the auto. just do some work to it. NOBODY can shift faster than a computer.</TD></TR></TABLE>
yeah but the auto gearing sucks
Bump for the same exact situation i'm in right now ...
Auto Mini-Me to Auto B18a1
I know to do the swap you'd need 94-01 motor mounts ..
.... I know to do the swap you'd need 94-01 motor mounts ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssbpturbohatch »</TD></TR><TR><TD CLASS="quote">if i'm not mistaken i think there is a gsr that comes in auto and i figure that might be a better tranny if it must be auto( )</TD></TR></TABLE>
like i said "I THINK"
Your tranny and the B series motor will not fit together. You need a B series tranny, I'd recommend getting the LS tranny to go with the LS motor. If you have a GS-R or Type-R tranny, you will have very high revs at cruising speed.
Something like 3000 at 60 for GS-R and close to 3500 at 60 with a Type-R tranny. Trannies are made to match up with the engine. However using one of those trannies will give you faster acceleration, but less of a max for each gear.
GS-R's were never made with an auto.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2001 »</TD></TR><TR><TD CLASS="quote">i just wanna kno about the wiring involved. will everything plug up?</TD></TR></TABLE>
Dude not to be rude but aparently you do not know to much about cars so ill save you the trouble. No it will not bolt directly right up you need new motor mounts and deopending on if you want to keep you a/c and power steering you may need to do some engine bay modifications. No everything will not plug up you need at least a different ecu and im not to sure if you need any rewiring. Just remember if your putting in a bigger motor **** aint easy and if you dont know what your doin get professsional help
when i say will everything plug up i mean the harness on the automatic b series tranny. sorry if i wans't clear enough for you. i'm not worryed about the motor bolting up to the chassis. god some ppl are **** "not to be rude"
93CharcoalHatch
10
Aug 1, 2005 07:13 PM
