LS (B18B) Into An 1993 Civic Hatch Wiring PLEASE Help .. Searched
alright well, i have an LS motor and ECU and all is OBD1, same as my car, and i was wondering what wiring will need to be done if any since there is no vtec with LS motor. Any help would be apritiated
Re: LS (B18B) Into An 1993 Civic Hatch Wiring PLEASE Help .. Searched (93CharcoalHatch)
i dont think there is any difference i think you just put that **** in but i may be wrong i am going to do the same swap soon so it would be good to know for sure
Re: (Rhythm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhythm »</TD></TR><TR><TD CLASS="quote">I did the exact swap in my 93 civic hatch and it was plug and play. If you have the harness from the new motor, use it, plug in the ecu and drive!</TD></TR></TABLE>
werd, all the plugs match up and no extra wiring is needed.
Re: (BROKE.eg)
so everything, every pin on the LS harness is the exact same as the stock civic harness? NO wiring whatsoever needs to be done ??? seems to easy haha
Re: LS (ek-NONE)
one last question.. i bought an engine with a cut harness.. can i use the entire engine harness from my stock D15B7 on my new B18B ?? both are obd1 and both 5-speed
Re: LS (93CharcoalHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CharcoalHatch »</TD></TR><TR><TD CLASS="quote">one last question.. i bought an engine with a cut harness.. can i use the entire engine harness from my stock D15B7 on my new B18B ?? both are obd1 and both 5-speed </TD></TR></TABLE>
its my last question on this i swear
its my last question on this i swear </TD></TR></TABLE>
You should be able to use it, just extend the wires for the o2 sensor since the d-series has it on the fron of the exhaust manifold and the b has it right before the cat.
bigwave1600
08-03-2001 08:19 AM
