Strange problems with B16
Old Apr 13, 2005 | 08:29 PM
N1ghtM0nkey's Avatar
Default Strange problems with B16
Hey guys, I've experienced some wierd stuff lately.
First: my stock tach never read correctly which didn't surprise me, but recently my aftermarket tach stopped reading correctly. On the highway revving about 4-5k if I would give it some gas the needles on BOTH of the tachs would jump forward and then jump back, as if bouncing off the rev limiter but the engine was accellerating smoothly.
Also in town if I get on it in 1st gear and hit vtec, the tach will almost wrap around from the 8 to the 1.
Second: After getting off the highway after a long drive, going through town a bit, and then shutting it off - it would die upon attempt to restart it. I only barely got it going by giving it gas at start up and holding it at 2k for awhile.
Finally: It used about a quart of oil over about 450 miles (drove to Nashville from IL) but there were some 100+ mph pulls on the way and I was revving 4-5k almost all the way there. I figured the oil just broke down or there was some blowby or something. It was not burning it, I had people follow me to confirm it, and it is not leaking anything. I've been checking the level regularly and it has not changed much if at all since then.
Any ideas what might be wrong with the tach(s)? I have new plugs, wires, dizzy cap looks new, so I'm thinking it's something else to do with the ignition.
Forgot to add that this is a 91 CRX HF w/ PR3 ECU and B16A and my aftermarket tach is a Sunpro Supertach II with the green wire tapped into the blue wire on the dizzy.
Old Apr 13, 2005 | 08:35 PM
Redline130's Avatar
Default Re: Strange problems with B16 (N1ghtM0nkey)
Sounds like your ignitor may be failing. Jumpy tachs and hard starts are some usual symptoms to an ignitor going out.
Old Apr 13, 2005 | 08:38 PM
SiR Inspired ED7's Avatar
mine used to that, i fixed it wel, it was the screw that was on the rotor that got loose and fell, i just put it on. and yay tack worky worky
Old Apr 13, 2005 | 10:10 PM
doublethink's Avatar
Default Re: Strange problems with B16 (88 Crx Si)
its dizzy related.
both those posts are good places to start.
Old Apr 14, 2005 | 02:20 AM
cbrodac0424's Avatar
Default Re: Strange problems with B16 (doublethink)
I have also heard that when your alternator starts to go out that it will cause your tach to jump back and forth but i have never seen this happen before so your guess is as good as mine but you might want to check that out if it is true.
Old Apr 14, 2005 | 05:05 AM
Default Re: Strange problems with B16 (cbrodac0424)
Good info. Thanks guys
Old Apr 14, 2005 | 07:48 AM
teler86's Avatar
if the alternator was causing you tachs to die first of your battery light would be on and also the radio wouldnt power on
Old Apr 14, 2005 | 08:08 AM
I don't have a radio, my car is pretty much gutted. Also, where would I get an ignitor for an OBD-0 B16? Would I have to buy an entire new dizzy? If not which car would I buy it for? Same for the alternator.
Old Apr 14, 2005 | 09:16 AM
Redline130's Avatar
Default Re: (N1ghtM0nkey)
Most any Honda ignitor from 88-00 will work.
Old Apr 14, 2005 | 08:57 PM
^ Can anybody verify that will work?
Old Apr 15, 2005 | 02:23 AM
96-EJ6 B18C's Avatar
Default Re: (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Most any Honda ignitor from 88-00 will work.</TD></TR></TABLE>
Yeah, as far as I know that is the case, but I would try to use one from a 90-91 Integra (closest match for your application). The alternator is not the issue, that will cause a whole different set of problems, from what you are describing, my guess would be a faulty ignitor.
eXcelonTypeR
Jun 9, 2005 08:17 AM
5thgenCory
Jul 18, 2004 12:08 PM
MUGEN_B16CIVIC
Jan 21, 2004 03:58 PM
EF8SIR
Jan 8, 2002 07:25 PM
EF8SIR
Jan 8, 2002 02:56 PM
