Spitting oil??? What the deal?
Old Apr 13, 2005 | 04:04 PM
Smooth_Imports's Avatar
Default Spitting oil??? What the deal?
I have oil comoing out of my compresser wheel and also a coating of oil in my charge piping. Does this mean my seals are bad or could it be somthing else.?
Old Apr 13, 2005 | 04:05 PM
B20TDC2's Avatar
Default Re: Spitting oil??? What the deal? (Smooth_Imports)
time for a rebuild .
Old Apr 13, 2005 | 04:20 PM
salt's Avatar
Default Re: Spitting oil??? What the deal? (B20TDC2)
before you do a rebuild, try an oil restrictor, its about $10 and solves LOTS of people problems.
Old Apr 13, 2005 | 04:28 PM
adseguy's Avatar
Default Re: Spitting oil??? What the deal? (salt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salt &raquo;</TD></TR><TR><TD CLASS="quote">before you do a rebuild, try an oil restrictor, its about $10 and solves LOTS of people problems.
agreed...not many people recommend this, but it's only $10
Old Apr 13, 2005 | 05:09 PM
SpeedDreamz.com's Avatar
Default Re: Spitting oil??? What the deal? (adseguy)
use a nitrous jet for the restrictor. drill it out to 3/32 and you are set.
Old Apr 14, 2005 | 04:05 AM
Jradrebel's Avatar
Default Re: Spitting oil??? What the deal? (SpeedDreamz.com)
i have oil burning out of my exhaust at boost... did compression test thats fine.. soo is it my turbo, haven't checked the charge pipe yet... also could a oil restrictor fix my problem??
Old Apr 14, 2005 | 05:05 AM
I'm running the oil line that came with the turbo kit. Would i still need a restictor? What PSI should the oil be at the turbo?
Old Apr 14, 2005 | 08:01 AM
Old Apr 14, 2005 | 08:06 AM
nonvtecD's Avatar
Yes the oil feed line that came in your kit is quite possibly to much pressure for your turbo. Even with my rebuilt T3 with an oil restrictor I still found oil in the charge pipes. A film, not like any puddles.
Old Apr 14, 2005 | 08:57 AM
so what size should i drop it down to? Like the same size as a -3 an?
Old Apr 14, 2005 | 11:47 AM
^^^6
Old Apr 14, 2005 | 02:11 PM
nonvtecD's Avatar
Just get a restrictor and turn it down.
marcj
Oct 6, 2008 12:16 PM
SpoolnByYou
Feb 14, 2006 05:31 PM
Cee_mon
Nov 18, 2005 06:11 AM
beautifulblue
Jun 14, 2004 04:13 AM
E-Rok
Apr 10, 2003 02:10 PM
