Need advice, 1cm scratch on cylinder wall; Hone entire cylinder?
Old Apr 13, 2005 | 02:45 PM
bb_one's Avatar
Default Need advice, 1cm scratch on cylinder wall; Hone entire cylinder?
Hello all, I'm in need of some advice.
I'm in the process of putting on another cylinder head to replace one with bent valves. Well, during the process I found a 1cm vertical scratch on the number 1 cylinder wall. The scratch is very faint and is very hard to see but I CAN barely catch it with my fingernail. I know something needs to be done about this but I'm unsure if I need to rehone the entire cylinder or is there something I can do about the scratch. It does NOT run the entire lenth of the cylinder wall, just 1 cm long about 1 inch down from the top of the block. Any input or advice on what I should do? Any help would be greatly appreciated, thanks.
Johnny
Old Apr 13, 2005 | 03:24 PM
Kendall's Avatar
Ideally, you would go ahead and have the cylinder honed. Trying to correct just a part of the wall will probably make it worse.
Old Apr 13, 2005 | 03:30 PM
1BadCvC's Avatar
Default Re: (Kendall)
Deffinatly re-hone it. if you do i m pretty sure youll need new rings, as well, in order to get a good seal.
Old Apr 13, 2005 | 03:47 PM
bb_one's Avatar
Default Re: (1BadCvC)
If thats the case, should I hone all 4 cylinders and get new rings for them all? Or will doing one cylinder suffice? I mean I don't want to cheap out on something this critical but the labor to get this all done can add up.
Unless I can hone them myself... can anyone give me some tip on doing this? I've done swaps and head swaps and such, but I've never done an engine build before.
Old Apr 13, 2005 | 04:29 PM
1BadCvC's Avatar
Default Re: (bb_one)
you prolly should re-hone and re-ring the block. As far as honing it yourself i dont think its too difficult but i just like leaving that up to my maching shop, just to ensure a good even hone.
Old Apr 13, 2005 | 04:53 PM
bb_one's Avatar
Yea thats true. I plan on just bringing the block to a machine shop and have them hone it down.
How difficult is it to remove the pins from the pistons? Can I do this without a hydro press?
Old Apr 13, 2005 | 04:54 PM
HamiltonRex's Avatar
I use a hone that goes in a hand drill, just dont overdo it and lube it.
Old Apr 13, 2005 | 04:55 PM
bb_one's Avatar
Default Re: (HamiltonRex)
Can you give me some details on that honing device? Also how were you able to make sure the hones were even?
Old Apr 13, 2005 | 08:01 PM
TrackSpeedRacing's Avatar
Default Re: Need advice, 1cm scratch on cylinder wall; Hone entire cylinder? (bb_one)
why would he rering the block? if anything, just go oversize and rebore.
Old Apr 13, 2005 | 09:04 PM
1BadCvC's Avatar
Default Re: Need advice, 1cm scratch on cylinder wall; Hone entire cylinder? (1320JDMGSR)
im pretty sure you should get new rings when you hone the cylinders. Bc the old rings have set to the original hone and with a fresh hone you need fresh rings in order to get them to seat properly.
Old Apr 14, 2005 | 04:17 AM
Flashmn's Avatar
Default Re: Need advice, 1cm scratch on cylinder wall; Hone entire cylinder? (1BadCvC)
General rule of thumb, always get new piston rings when you take the pistons out, the old ones wont seal anymore, even if you dont do anything to the block. Always new rings.
Old Apr 14, 2005 | 04:38 AM
bb_one's Avatar
Default Re: Need advice, 1cm scratch on cylinder wall; Hone entire cylinder? (Flashmn)
Thanks for all the replies.
JFG Kevin
Sep 8, 2006 07:27 PM
SiR Adam
Feb 24, 2006 09:27 AM
fastcivicboy
Apr 27, 2005 11:21 AM
bb_one
Apr 14, 2005 02:45 PM
