B-Series vtec solenoids
Old Apr 13, 2005 | 02:12 PM
wutupnut's Avatar
Default B-Series vtec solenoids
I was wondering if anyone knew if all B-Series vtec solenoids were the same? Mine seems to be going bad on my b16a2 and was wondering if the solenoid off a jdm b16 would work fine?
Modified by wutupnut at 9:54 PM 4/13/2005
Old Apr 13, 2005 | 06:55 PM
wutupnut's Avatar
Default Re: B-Series vtec solenoids (wutupnut)
anyone?
Old Apr 13, 2005 | 07:10 PM
civictildeath's Avatar
SWITCH ASSY., VALVE TIMING OILPRESSURE part # 18159
is same for SOHC and DOHC. not sure if that is the vtec selenoid part you are talking about but think it is. got at
http://www.hondaautomotiveparts.com
Old Apr 13, 2005 | 07:55 PM
jdmb1697ek's Avatar
jdm b16 soleniod dont have a vtec pressure switch so you better also use a jdm ecu if your gonna use a jdm soleniod. are your have a cel if your using a usdm ecu with a jdm solenoid
Old Apr 13, 2005 | 08:46 PM
wutupnut's Avatar
Default Re: B-Series vtec solenoids (beyoboyb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyoboyb &raquo;</TD></TR><TR><TD CLASS="quote">jdm b16 soleniod dont have a vtec pressure switch so you better also use a jdm ecu if your gonna use a jdm soleniod. are your have a cel if your using a usdm ecu with a jdm solenoid</TD></TR></TABLE>
Had no idea the jdm soleniod didn't have a pressure switch. Thank you for the info
BrizzlEK
Apr 2, 2009 06:11 AM
teamworxek9
Honda Civic (2001 - 2005)
Jul 29, 2007 04:27 PM
duceducecord
Jan 29, 2007 03:14 PM
LeftCorner
Oct 1, 2003 03:42 AM
Hondasaurs
Apr 30, 2003 01:57 PM
