JDM D15B and USDM D15B2
Old Apr 13, 2005 | 11:32 AM
JRSC EM1's Avatar
Default JDM D15B and USDM D15B2 Help Please!!!!
Im not terribly familiar with SOHC motors. So I was wondering if the two motors, JDM D15b and USDM D15b2 took the same tune up parts. Is it going to be pretty much the same thing as a JDM B16a and the USDM B16A2? Its a 30K motor (yeah right) for my friends 90 Civic DX 4 Dr. If you know the answer please help. If you are unsure do not respond. Thank you for your help!
Modified by JRSC EM1 at 9:44 PM 4/13/2005
Old Apr 13, 2005 | 11:34 AM
EP3_05's Avatar
Default Re: JDM D15B and USDM D15B2 (JRSC EM1)
D15b is a sohc VTEC engine while the stock dpfi sohc non-VTEC engine in the 88-91 civic/crx dx/lx. As far as tuneup parts what parts in particular?
Old Apr 13, 2005 | 11:46 AM
Mach69's Avatar
As far as tune ups, most parts you need for the block are from the civic VX ('92-'95) and most parts for the head are for a d16z6 ('92-'95 as well).
Old Apr 13, 2005 | 11:51 AM
JRSC EM1's Avatar
Default Re: JDM D15B and USDM D15B2 (91civic)
plugs
wires
v.c. gasket set
water pump
timing belt
idler pulley
Intake Man Gasket
Exhaust Man Gasket
cap
rotor
oil pan gasket
PCV
Also, I was told that the Intake manifold was the same and the old one (usdm) would bolt right up to the JDM motor. Is this correct?
Modified by JRSC EM1 at 9:20 PM 4/13/2005
Old Apr 13, 2005 | 12:30 PM
JRSC EM1's Avatar
Bump...
Plus I will be doing the swap on a Sunday, so no dealers will be open.
Old Apr 13, 2005 | 03:33 PM
JRSC EM1's Avatar
Default Re: (rexwreck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexwreck &raquo;</TD></TR><TR><TD CLASS="quote">no, the D15B2 intake manifold has only dual point fuel injection. The distributors are significantly different as well. Not sure about the timing belt or the other stuff</TD></TR></TABLE>
The intake manifold didn't come with the engine and the guy told me that the one on the car (D15B2) would work with the D15B. Am I going to be able to just drop this D15B motor in to the 90 DX and go, or will there be a lot of other things that will come up? We thought that, per the motor sales company, it was a straight swap.
Old Apr 13, 2005 | 04:19 PM
JRSC EM1's Avatar
The D15b2 which is in the car is set up stock with the 2 injectors. The D15B didnt come with the IM. Its an adults car that just wants it to run and pass visual for cali smog. This motor was purchased because it was really cheap ($200), not because of performance. Im doing this as a favor to him, and just need to get the facts ASAP. I searched a little but all I found was for performance gains, dont want any of that. Just want the least expensive way so he can have his car back in running condition.
In addition to the above ?'s.... will the D15B2 IM work with the D15B?
Modified by JRSC EM1 at 1:32 AM 4/14/2005
Old Apr 13, 2005 | 04:43 PM
See65's Avatar
Is it a jdm D15b or a jdm D15b vtec?
Old Apr 13, 2005 | 04:45 PM
JRSC EM1's Avatar
Default Re: (See65)
Non-VTEC JDM D15B
Old Apr 13, 2005 | 05:05 PM
See65's Avatar
All of the exterior parts off the old motor will bolt right on not sure about the internals though.I ran one of those motors for a few years in my 91 hatch with dpfi on it and never had a problem with smog.
Old Apr 13, 2005 | 05:07 PM
JRSC EM1's Avatar
Default Re: (See65)
Just saying it again. I dont want any performance gains. Just to get this car up and running with the JDM NON VTEC D15B.
Old Apr 13, 2005 | 05:09 PM
green91's Avatar
i think they will switch right over...
Old Apr 13, 2005 | 05:11 PM
91civicEX's Avatar
Default Re: (JRSC EM1)
non vtec d15b will be EXACTLY the same as a d15b2. the problem with jdm is that they dont put a number after the letter in the engine code so you cant identify motors without looking at em. if the sparkplugs are on the back of the head (near the IM) then its the same as a d15b2
Old Apr 14, 2005 | 06:53 AM
JRSC EM1's Avatar
Default Re: (91civicLX)
The spark plugs are on the same place on both motors, right on top of the VC on the IM side of the motor. So it should be a direct swap? Im still curious about the tune up parts I listed above. Someone else tried to help me with that, but I dont know if they were for the VTEC or Non VTEC version. Any ideas?
Old Apr 14, 2005 | 04:04 PM
See65's Avatar
When I still had mine in my car I just asked for 91 1.5 hatch parts and never had a problem.
Old Apr 14, 2005 | 04:09 PM
phatrick2332's Avatar
If the block you are swapping says d15b, Its a vtec sohc. Im pretty sure the only non-vtec sohc that came out of japan was the zc, and it will just say zc right on the block.
Maybe im wrong.
JRSC EM1's Avatar
Default Re: (See65)
Thanks . I used to work in a Honda Parts dept, so I called a friend and had him order the parts for 4 different years and models of cars. He said I could return what I don't use. I think I should be set.
Old Apr 14, 2005 | 04:28 PM
green91's Avatar
Default Re: (phatrick2332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">If the block you are swapping says d15b, Its a vtec sohc. Im pretty sure the only non-vtec sohc that came out of japan was the zc, and it will just say zc right on the block.
Maybe im wrong.</TD></TR></TABLE>
you're wrong. there is a jdb d15b which is identicle to the d15b2. there is also a sohc vtec d15b... and theres even a vtec-e d15b.
Swan507
Jul 26, 2018 08:54 AM
CantGetRich
Oct 3, 2005 09:18 AM
JRSC EM1
Apr 13, 2005 02:58 PM
chaos304k
Jul 7, 2004 09:52 PM
Evan
Aug 29, 2002 06:04 AM
