vtec pressure switch Q"
hi my question is wich cable of the vtec pressure switch is the one that goes to ground and wich to the ecu ?
btw I have a jdm p72 ecu ,b18c1 in a eg
Modified by racing_beat at 10:17 AM 4/13/2005
BBBBBBBBBBB.......UUU..........UUU....MMM......... .......MMM.....PPPPPPPPP
BBBBBBBBBBBB.....UUU..........UUU....MMMM......... ...MMMM.....PPPPPPPPPPP
BB..............BBB.....UUU..........UUU....MMMMM. .......MMMMM.....PPPP......PPPP
BB.............BB........UUU..........UUU....MM... MMM..MMM...MM.....PPPP......PPP
BBBBBBBBBB.........UUU..........UUU....MM....MMMMM M....MM.....PPPPPPPPP
BB.............BB........UUU..........UUU....MM... ...MMMM......MM......PPP
BB.............BBB......UUUU......UUUU....MM...... ...............MM......PPP
BBBBBBBBBBBB......UUUUUUUUUU.....MM............... ......MM......PPP
BBBBBBBBBBB.........UUUUUUUUU....MMMM............. ...MMMM...PPPPP
now one more question
when i bough the engine harmness I got it without the vtec pressure switch connector , and I was woundering if i can use one frome the stock d15b8 engine I mean I cut one for example the iab or any other connector that fits the vtec pressure switch and then put the wires together and ? is there any way I could do that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz »</TD></TR><TR><TD CLASS="quote">If you find a plug that fits, that should probably work.</TD></TR></TABLE>
It will, that's what I did. Yes black is ground. On the p72, does it ground to the chassis or A26?
Freya Franco
Engine Management and Tuning
Dec 13, 2017 10:49 PM
Takumi Fujiwara
Jul 23, 2006 09:18 PM
