engine not firing on all cylinders, changed plugs/wires now it wont start at all wtf???
Old Apr 13, 2005 | 08:52 AM
Littlegreend15's Avatar
Default engine not firing on all cylinders, changed plugs/wires now it wont start at all wtf???
i'm puttin a b18c in my 94 cx and it wouldn't idle right, it'd start run really badly like it wasn't firing on all cylnders, so i replaced the plugs, and now it won't start at all, it turns over but it won't start
Old Apr 13, 2005 | 09:59 AM
94DOHCDELSOL's Avatar
Check the coil
Old Apr 13, 2005 | 10:04 AM
mct121's Avatar
Default Re: engine not firing on all cylinders, changed plugs/wires now it wont start at all wtf??? (Littleg
Did you get a CEL?
Old Apr 13, 2005 | 10:07 AM
Luserkid's Avatar
Default Re: (94DOHCDELSOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94DOHCDELSOL &raquo;</TD></TR><TR><TD CLASS="quote">Check the coil</TD></TR></TABLE>
Also make sure your wires are in the correct order
34
12
4321
Old Apr 13, 2005 | 10:08 AM
Ignitecivic's Avatar
did u check firing order?
Old Apr 13, 2005 | 11:26 AM
X2BOARD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic &raquo;</TD></TR><TR><TD CLASS="quote">did u check firing order?</TD></TR></TABLE>
could be the current problem
Old Apr 14, 2005 | 07:27 AM
Default Re: (Luserkid)
i checked the firing order, i think its right, anyone know where i can find a diagram of that? and i guess i'll have to check the coil too
Old Apr 14, 2005 | 07:53 AM
94ls's Avatar
be sure the plugs aren't loose...as retarded as that sounds...mine came loose cuz i forgot to tighten down on 2 and 4 and i was misfiring like crazy
sohc90rex
16
Dec 21, 2005 09:20 PM
CWITR
May 3, 2005 04:38 PM
D3LSLO
Sep 24, 2003 12:13 PM
E Swift
Sep 3, 2003 05:46 PM
JBG's Ferio
Jul 30, 2003 06:41 PM
