Suspension technique sway bars for 88 crx si
i was wondering if they made 88 specific rear sway bars for just 88 crx si's. i have a set of st sway bars but dont seem to look like it will bolt on correctly with the control arm and struts being all different. 88 si does have a stock sway bar tho but doesnt look the same way as the st sway bars. will i have to convert to 89-91 LCA and struts? hope not
from what i hear you either have to convert the rear suspension to a DA or 90-91 CRX cause the 88 was the weird year since it was the begining of a new body style. im pretty sure though that you have to convert the suspenion to a newer model EF or a DA
The front should be the same as any 88-91 crx, it will definitely bolt up. The only thing different on the 88's is that the rear lca is a cup style(like the ITR's). It should work the same way since the way the instructions describe the install is to use their bracket/endlinks/bolts joined through the rear shock/lca. So the actual part of the sway bar kit that links to the rear lca is through the bolt that ties your shock to the lca.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource »</TD></TR><TR><TD CLASS="quote">you can also order the "adaptor kit" for the 89-91 units to mount up to the 88 style.
ST still has em</TD></TR></TABLE>
do you know where i can get this adapter kit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeySpec »</TD></TR><TR><TD CLASS="quote">The front should be the same as any 88-91 crx, it will definitely bolt up. The only thing different on the 88's is that the rear lca is a cup style(like the ITR's). It should work the same way since the way the instructions describe the install is to use their bracket/endlinks/bolts joined through the rear shock/lca. So the actual part of the sway bar kit that links to the rear lca is through the bolt that ties your shock to the lca. </TD></TR></TABLE>
so the bar mounts thru the strut mount??? does it piggy back the strut mount??
just wondering because my DX rear lcas dont have any provisions for a rear bar.
Louie B.
43
Dec 11, 2007 09:15 AM
tysf
Aug 19, 2003 08:41 PM
