Want to Buy Want to Trade/Want to Buy
WTB: 92-95 4040 proportioning valve
Old Apr 12, 2005 | 08:08 PM
pissedoffsol's Avatar
25 Year Member
Default WTB: 4040 proportioning valve
like the title says, i need a 4040 from a DA teg non-abs, or a 94+ RS teg, non ABS.
Modified by pissedoffsol at 8:31 PM 4/15/2005
Modified by pissedoffsol at 8:32 PM 4/15/2005
Old Apr 12, 2005 | 09:02 PM
BlueIntegraBoy's Avatar
Default Re: WTB: 92-95 4040 proportioning valve (pissedoffsol)
A DA 4040 prop valve will fit.
Old Apr 13, 2005 | 05:16 AM
25 Year Member
Default Re: WTB: 92-95 4040 proportioning valve (BlueIntegraBoy)
i heard the hardlines on the firewall don't line up?? can anyone else verify that?
Old Apr 13, 2005 | 08:54 AM
25 Year Member
up
Old Apr 13, 2005 | 02:50 PM
25 Year Member
anyone? Buler?
Old Apr 13, 2005 | 02:54 PM
They line up. The prop valves have the same shapes and thus the same ports for the hardlines.
Old Apr 13, 2005 | 07:24 PM
25 Year Member
ok, somebody sell me something that works
Old Apr 14, 2005 | 08:44 AM
25 Year Member
up up up... need this.
Old Apr 14, 2005 | 08:03 PM
25 Year Member
no body has one? come on...
Old Apr 14, 2005 | 08:05 PM
Dang EG's Avatar
You are supposed to use the 40/40 from the DA..I just installed on in my hatch and it works fine and lined up perfect..only thing different is the mounting holes..Only one hole lines up but that is nothing....I will take a pic of it if I have time ...
Old Apr 14, 2005 | 08:07 PM
Default Re: WTB: 92-95 4040 proportioning valve (Dang EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dang EG &raquo;</TD></TR><TR><TD CLASS="quote">You are supposed to use the 40/40 from the DA..I just installed on in my hatch and it works fine and lined up perfect..only thing different is the mounting holes..Only one hole lines up but that is nothing....I will take a pic of it if I have time ...</TD></TR></TABLE>
Could you just swap the brackets? pissedoffsol, I have a DA 4040 for sale.
Old Apr 14, 2005 | 08:08 PM
Dang EG's Avatar
Its not recommended because if you try to, there is a spring in the middle of the prop valve and things can get bad...Just install it the way it is and perfecto!
Old Apr 14, 2005 | 08:10 PM
Dang EG's Avatar
ask this guy if he has it. He has a wrecked DA and it wouldnt hurt to ask..
https://honda-tech.com/zerothread?id=1213336
Old Apr 15, 2005 | 07:58 AM
25 Year Member
i would still prefer to get an EG si one, as i 100% know it works and uses all the stock mounting options. holding off on DA's for now.
someone's gotta be parting out a car or something...
Old Apr 15, 2005 | 09:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">i would still prefer to get an EG si one, as i 100% know it works and uses all the stock mounting options. holding off on DA's for now.
someone's gotta be parting out a car or something...</TD></TR></TABLE>
They only had 3040 because the front disks were 9.5", not 10.25"
Old Apr 15, 2005 | 11:22 AM
25 Year Member
Modified by pissedoffsol at 8:33 PM 4/15/2005
Old Apr 15, 2005 | 04:31 PM
25 Year Member
alright i did some research, and the DA non-abs or the DC2 RS non-abs 4040 is what i need.
white_gsr
Apr 5, 2010 02:17 PM
Civic92Turbo
15
Jan 24, 2005 11:22 PM
SiRcyrusEH2
May 18, 2004 05:27 PM
