LS rod question
Old Apr 12, 2005 | 05:25 PM
kasso's Avatar
Default LS rod question
i own a 95 integra se soon to have a b16 head on it. i have a couple questions: 1)Is it cheaper to just change the rod bolts than to change out the entire rod (referring to labor only) 2) does it make sense to change out rods to forged rods and keep stock pistons? 3) whats the cheapest way to allow my motor to rev out to at least 8k rpm?
p.s. oil pump and water pump will be changed as well as timing belt. TIA.
Old Apr 12, 2005 | 07:35 PM
mmuller's Avatar
Mad Scientist
Default Re: LS rod question (kasso)
change the rod bolts to ARP ones. resize the rod.
besides that stock is plenty strong.
Old Apr 12, 2005 | 08:18 PM
kasso's Avatar
Default Re: LS rod question (mmuller)
ya but is the labor any cheaper than new rods/bearings?
Old Apr 12, 2005 | 09:56 PM
Kendall's Avatar
You may want to have the rotating assembly balanced as well.
Old Apr 12, 2005 | 10:56 PM
Combustion Contraption's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">You may want to have the rotating assembly balanced as well.</TD></TR></TABLE>
MAY want to?
Old Apr 13, 2005 | 04:15 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (LsVtec92Hatch)
Crank balance
ARP Rod bolts
You're good to 8K
Old Apr 13, 2005 | 09:52 AM
Finger Lickin' good's Avatar
Default Re: (LSVTEC 91 Civic)
you gotta get an ecu good for 8000rpms or else BOOM!
Old Apr 13, 2005 | 04:55 PM
kasso's Avatar
Default Re: (D-CeReaL#4)
ya i have a p28 chipped with uberdata
Old Apr 13, 2005 | 09:24 PM
b18avtec(A!!M0TOR)'s Avatar
Default Re: (kasso)
i know a lot of people that go to 8 grand all day on a stock ls bottom. so if you would want to go cheap that would be the cheapest way to go.
Old Apr 14, 2005 | 04:50 AM
iakona's Avatar
how do you resize a rod?
and when you do change out the rod bolts, should new bearings be put in too?
Old Apr 14, 2005 | 07:47 AM
95lstegman's Avatar
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18avtec(A!!M0TOR) &raquo;</TD></TR><TR><TD CLASS="quote">i know a lot of people that go to 8 grand all day on a stock ls bottom. so if you would want to go cheap that would be the cheapest way to go. </TD></TR></TABLE>
i konw a lot of people that go to 8 grand all day and later that year go BOOM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">how do you resize a rod?
and when you do change out the rod bolts, should new bearings be put in too?</TD></TR></TABLE>
a) take it to a machine shop to resize
b) yes. new bearings are always nice, and since they're not more than like $150 even for Honda ones, just do it. bearings are kind of important, no? you never reuse a bearing. if you untorque the bolts that hold it, replace it.
Old Apr 14, 2005 | 08:20 AM
iakona's Avatar
thanks.
as far as resizing, you're speaking of the wrist pin, right? because the LS is a different size than the ITR?
Old Apr 14, 2005 | 01:18 PM
overclocking1's Avatar
178k miles ls stock bottom end 8k rpms everyday still not even a tick. we tried to blow it up once because we have a gsr motor for it and couldnt get it to come apart so we left it in the car still holding strong to this day. I know when he pulls in my drive because instead of his horn all i hear is the 8k rev limiter. I am overly surprised of the strength of these motors.
However i dont recomend doing 8k on a stock bottom end if you care about it. arp and a balance is the way to go.
Old Apr 14, 2005 | 01:35 PM
mmuller's Avatar
Mad Scientist
Default Re: (overclocking1)
resizing meaning you have to get the rod end shaved and re-honed round after you torquee the arp's down.
the increased torque of the arp's will cause the rod to egg shape.
HRubss
May 6, 2014 05:08 AM
Lsweez
Nov 28, 2007 04:03 PM
evil b
Aug 19, 2004 05:17 PM
b2Ovtec
11
May 11, 2004 12:51 AM
