Halo Projector Headlights messing up alternator
Old Apr 12, 2005 | 03:41 PM
acpmadness's Avatar
Default Halo Projector Headlights messing up alternator
Yo,
The check engine light came on yesterday morning so I took it to the honda service place and they ran some tests on it. They said to much voltage is coming from the headlights and messing up the alternator. The reason I think it's doing that is because my freinds and I weren't sure what to wire the halos too. So we took the 2 red wires on each headlight and spliced them into the dimm lights. We took the black wires from 1 headlight and grounded them and the ones from the other headlight and directly connected them to the battery. The instructions only said connect the black wires to the negative parking wire. We didn't know how to do that so that's why we did it the other way. Anyone know how to connect the wires the wright way so they will stop draining my alternator? Or heard of anything like this before? Thanx for any help.
my car is a 2000 Accord LX 2D coupe
headlights: http://cgi.ebay.com/ebaymotors...%3AIT
Old Apr 12, 2005 | 04:47 PM
YeuEmMaiMai's Avatar
Default Re: Halo Projector Headlights messing up alternator (acpmadness)
the dealer will tell you to replace them with the stock headlights. My friend has a 99 accord and when she installed highwe wattage bulbs it caused her car's check engine light to come on. The computer senses an abnormal load on the alt and will throw the check engine light. When she installed normal headlight's the problem dissapeared.
I have a 94 accord and I can use the higher wattage bulbs in both the low and high beams without any issues.
Old Apr 12, 2005 | 05:43 PM
acpmadness's Avatar
Default Re: Halo Projector Headlights messing up alternator (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">the dealer will tell you to replace them with the stock headlights.</TD></TR></TABLE>
Yeah that's what he said. What should I do? I don't get why they would sell these headlights for this car and then not work right.
Old Apr 12, 2005 | 07:01 PM
TOP END MS's Avatar
Just one more reason not to get 'halo's' IMO ::Sorry guys::
Old Apr 13, 2005 | 11:52 AM
acpmadness's Avatar
Old Apr 14, 2005 | 02:39 PM
SpeedFreak77's Avatar
Default Re: (acpmadness)
Are you running high wattage bulbs with the halo's??
Old Apr 14, 2005 | 03:40 PM
acpmadness's Avatar
Nope, just the ones it came with.
I disconnected the halos completly last night so only the parking, dimms and brights are connected and the check engie light came back on this morning. If I put the stock lights back in do u think the check engie light will go off?
Modified by acpmadness at 5:10 PM 4/14/2005
Old Apr 14, 2005 | 05:29 PM
You can try putting the stock lights back in, but try taking out the lights that came with it and put the stock lights in with the halo's.
Old Apr 14, 2005 | 07:22 PM
iam7head's Avatar
Default Re: (SpeedFreak77)
replace it with oem spec wattage bulb before you overload your harness and start melting stuff.
Silverstar do sell oem wattage bulb that is not terribly yellowish.
and yeah, halo headlight=
Old Apr 15, 2005 | 05:48 AM
hometheaterman's Avatar
Default Re: (iam7head)
Eurolite sells Xenon Crystals that I don't think are DOT approved but don't have yellowish to them and you can get them in stock wattage. They look white with some blue or really blue if you only have one headlight Eurolite and the reflect blue when shining them up against something white so they look nice yet won't melt stuff as they are stock wattage.
Old Apr 15, 2005 | 07:16 AM
Vanilla Sky's Avatar
install yourself some relays and bigger wiring before you burn your car down
rpluto
Oct 16, 2018 04:54 PM
95streetciv
Mar 31, 2009 11:29 AM
EGmikeH22
Oct 4, 2005 06:43 AM
civcexcoupeblack
Jun 23, 2003 04:34 PM
shauniewalnuts
Mar 8, 2003 02:18 PM
