Crank Fluctuation Sensor??? Will it rob hp?
Old Apr 12, 2005 | 03:17 PM
maka's Avatar
Default Crank Fluctuation Sensor??? Will it rob hp?
just wondering if the sensor not being hooked up will effect the hp or the way the car runs? what exactly does it do? thanks.
Old Apr 12, 2005 | 04:56 PM
maka's Avatar
Default Re: Crank Fluctuation Sensor??? Will it rob hp? (maka)
hmmmm????
Old Apr 12, 2005 | 05:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
all it does is tell the ECU where a missfire occurs, basically telling it which cylinder is causing the missfire. and in some cases, i dont know about honda's but in toyota's and lexi's it will tell you % of time that cylinder is missfiring. it is basically an obd2 only sensor. notice it isnt on any JDM engines. because they still use obd1 software.
Old Apr 12, 2005 | 05:09 PM
maka's Avatar
Default Re: Crank Fluctuation Sensor??? Will it rob hp? (boostedcivicsir)
so, with that said, they wont really rob hp right?
Old Apr 12, 2005 | 05:11 PM
Mr. Badwrench
alls it does is just tell the ecu where the crank is, no it shouldnt rob power. i may be wrong, but i am abo9ut 98% sure of it.
nothing_shocking
Oct 5, 2011 09:00 AM
nels00n
19
Aug 16, 2010 08:04 AM
jjmcmana
Nov 1, 2008 09:02 AM
jdmgeezer
Feb 10, 2008 11:22 PM
TheOwnrOfTheEk9
Mar 7, 2006 06:10 PM
