Serious Wiring Problems.
OK, So I put the 97 b18b1 in the 94 civic I am using the 97 integra harness. I pluged in all the plugs I can find. There are still alot of plugs left. I dont know what I should do. There is no power to the starter when I turn the key. You can here a click under the dash but that is it. Also the Vafc doesnt turn on wich is making me believe that I am not getting any power to the computer. What could be wrong and why is there so many left over plugs? Thanks
OBD1 and OBD2 owns you...I'm not too sure if you can use the 97 harness or should you use your factory harness but if you do a quick search you will find your answer.
you shoulda just used the DX harness on the old motor your ripped out..changed alt and dizzy componets....and injectors...and your set....make life hard tho....
johnjw
Jan 28, 2008 12:59 PM
