Radio Diagram for 97 civic
Hey Ht
i searched all around for the 97 civic radio diagram, but there isn't an exact one that matches. Im trying to install an after market radio into my civic, but im having trouble with wiring. i have a harness, but the color of the wires are off. Any help would be apperciated.
Re: Radio Diagram for 97 civic
Google search produced:
http://www.modifiedlife.com/1996-hon...-instructions/
Appears that 96-98 were the same. Hope this helps.
thanks for the help. i am currently using a harness, but i need to splice the harness so it can connect to the harness for my alpine headunit
H-T White Ops
ok so when i pulled out my radio. there are three plugs. the one that plugs directly into the the radio (white) and two more (green). ive searched and searched but nothing is telling me what those other two green plugs go to. an alarm system maybe? any useful information would be helpful. yes i have a haynes manual and a chiltons but im not savy enough to really understand what this is telling me. i just installed all the 99-00 heater boxes and put my dash back together. and i still dont understand what im supposed to do with these two green plugs. so im assuming that i never got any check engine lights that they are no big deal but would still like to know what they are used for regardless. thank you very much for useful inputs and help.
H-T White Ops
One of the green plugs is for the keyless entry (which is built into the stock radio). I think the larger one is for the factory optional alarm.
Anyone still willing to lend some advice on this topic?
I just bought a 96 Civic Lx (I believe) 5-spd. I was trying to wire the radio since I noticed it kept cutting out. Whoever worked on these wires before mustve thought it was easier to just hack the whole harness so its a puzzle to me.
I see a lot of diagrams say the Wht/Blu wire is for the constant and the Yllw/Red us the ignition. When I connect my radios yellow constant wire to the cars Wht/Blu wire and do the same with the Red - Yllw/Red, my radio doesn't turn on.
For some reason it only turns on when I connect the yellow wire and the red wire together with the Yllw/Red wire. This keeps me from saving the settings for my music. I'd appreciate any advice I can get. Thank you
Circuit diagram for radio:
Youre a legend man. I've only been looking inside and gave no thought to the outside fuses. Do you think its okay to replace it with some 10A or 15A fuses? Or would that over power it?
ALWAYS install fuses with the specified amperage rating. Not doing so risks wire damage or worse (car fire).
It was blown. I didn't have an extra 7.5a so I took the 7.5a fuse from the interior lighting and checked. Low and behold that was exactly my issue. Im at work currently so I took a short 15 to go play with it. I put the wires in there respective locations with eachother and once I changed that fuse the radio worked perfect and its saving my settings now. Im glad I joined this forum. Thanks for your help man! now I can jam with the settings I want.
rossockr
Audio / Security / Video
03-05-2003 11:35 PM
