just got my car aligned
Old Jan 29, 2002 | 12:28 PM
albert butterbikini's Avatar
New User
Default just got my car aligned
i installed zeal B2 coilovers this past weekend and dropped my R about 1.25" all the way around. Here are my alignment specs:
Camber
LF -1.6
RF -1.24
LR -2.16
RR -2.20
I was suprised that my camber readings were almost within spec. my toe is adjusted to 1/16 total toe out in the front and 0 in the rear. Can someone tell me why 0 toe in the rear is out of spec - dosen't that mean the tires are perfectly parallel to one another?
Old Jan 29, 2002 | 12:31 PM
Reid's Avatar
Global Moderator
Default Re: just got my car aligned (typeR158)
LR -2.16
RR -2.20
Damn, how much did you lower it? That's terrible rear negative camber. 0 Toe in the rear means the tires are parallel.
Old Jan 29, 2002 | 01:01 PM
typer_801's Avatar
Typically cars are aligned slightly with toe-in in the rear to help reduce oversteer, at least the front drive cars I've owned have spec's like that.
Old Jan 29, 2002 | 01:54 PM
norice's Avatar
Default Re: just got my car aligned (typer_801)
That is a lot of rear negative camber. I would have put some washers between the upper control arm and the chassis to bring it to -1.5 degrees or so.
Spec, if a recall, is a maximum of -1.5 degrees front and rear. You are well out of spec on the rears.
[Modified by norice, 2:56 PM 1/29/2002]
Old Jan 29, 2002 | 05:46 PM
New User
Default Re: just got my car aligned (norice)
min spec for rear camber is -1.96 and for the front it is -1.52 according to the alignment print out from the dealer for 97-01 R's. What thickness washers should i start with?
Old Jan 29, 2002 | 05:48 PM
sgT's Avatar
sgT
the toe-in on the front is to make the car want to go straight.
hard_boiled_EG
May 2, 2008 03:59 PM
2000turbosi
Mar 26, 2006 02:51 PM
RallyRedGT-V6
May 19, 2004 04:00 AM
1.7na
Mar 20, 2003 03:22 PM
