Measuring Cylinder Head Height
Old Apr 12, 2005 | 07:12 AM
legendboy's Avatar
Default Measuring Cylinder Head Height
The FSM gives a new cylinder head height range to a couple thou. I'm wondering where I make this measurement at! (obviously one side will be the deck surface) Doesn't say where to measure it. This is to determine how much a head has been decked.
B18C new height is 5.589" - 5.593"
Its not from the deck to the valve cover mating surface. Thats about an inch taller than the specs. Any ideas?
Old Apr 12, 2005 | 11:06 AM
IN VTEC's Avatar
Default Re: Measuring Cylinder Head Height (legendboy)
It's probably to the mating surface of the cam caps. You use a large micrometer to get deep into the head....pretty similar to one you would use to measure the deck height on a cylinder block.
It can also tell you if the deck is parallel to the cam caps.
Old Apr 12, 2005 | 02:22 PM
legendboy's Avatar
Default Re: Measuring Cylinder Head Height (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">It's probably to the mating surface of the cam caps. You use a large micrometer to get deep into the head....pretty similar to one you would use to measure the deck height on a cylinder block.
It can also tell you if the deck is parallel to the cam caps.</TD></TR></TABLE>
yes exactly what i found out! thanks!
StreetEG
78
Nov 27, 2005 04:58 PM
high_revs
Jun 28, 2005 08:47 AM
legendboy
Apr 12, 2005 04:27 PM
WoodlockAsHell
Jan 31, 2005 04:57 AM
