Where can i get these parts?
Old Apr 12, 2005 | 05:53 AM
SpeedMachine's Avatar
Default Where can i get these parts?
I finally figured out my oil leak. I got it on a lift and they said its the oil filter housing gasket....Does anyone know where I can get this part or just the whole housing all together?
Old Apr 12, 2005 | 06:36 AM
Jagan'92's Avatar
Default Re: Where can i get these parts? (SpeedMachine)
You mean the oil cooler o-ring? 3-4$ from a dealership - or use san-leandro (slhonda.com) or majestic honda if you want it online.
Old Apr 12, 2005 | 06:48 AM
Default Re: Where can i get these parts? (Jagan'92)
i dont know is that the same thing?
Old Apr 12, 2005 | 09:42 PM
PrettyLude's Avatar
that's the hidden leak people don't see
Old Apr 13, 2005 | 06:35 AM
Default Re: (PrettyLude)
but is oil cooler o-ring same as oil filter housing gasket? thats what the guy at midas called it. i dunno if there is different names for it and i want to be sure before i order it
Old Apr 13, 2005 | 07:44 AM
SiRLudeVtec's Avatar
Default Re: (SpeedMachine)
the oil filter gasket? just get a new oil filter....it should have the little gasket in the inside....it shouldn't cost much at all....go to an indylube or mobile1 store or something....i bet your oil leak is bad....my galant had the same problem.
Old Apr 13, 2005 | 09:06 AM
577HondaPrelude's Avatar
Default Re: (SiRLudeVtec)
I bet your mechanic is just calling the oil cooler an "oil filter housing", and the O-ring is what you need.
Old Apr 13, 2005 | 09:54 AM
Default Re: (577HondaPrelude)
well i am sure that he is referring to the place where the oil filter is screwing into. is that called the oil cooler b/c if it is than i got my problem solved
Old Apr 13, 2005 | 01:25 PM
Jagan'92's Avatar
yeah the filter screws onto the oil cooler. The cooler comes off, and there is a gasket between the cooler and the engine block.
Here's a recent thread of that problem : https://honda-tech.com/zerothread?id=1119603
Old Apr 13, 2005 | 05:38 PM
Default Re: (Jagan'92)
THANKS A LOT....Consider the thread closed.
dljones8218
Honda Civic (2006 - 2015)
Apr 24, 2019 06:04 PM
wickidnis
Jul 23, 2010 09:11 AM
chiaxi2002
Apr 9, 2010 08:56 PM
B16CivicEX
May 30, 2006 03:15 PM
samaccord
Feb 13, 2004 07:03 PM
