Acura coded radio needs code every time?
I put an old Acura tape deck in my car. It needed a code to turn on, as I know they do. But it asks for the code every time I turn on the car. Is this normal? Is there anything I can do to stop this? It isn't a big deal, just odd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheezit »</TD></TR><TR><TD CLASS="quote">I put an old Acura tape deck in my car. It needed a code to turn on, as I know they do. But it asks for the code every time I turn on the car. Is this normal? Is there anything I can do to stop this? It isn't a big deal, just odd. </TD></TR></TABLE>It's only normal if there is no backup power, [constant] check the 7.5A fuse in the engine bay fuse box, do you also loose the radio presets?
94
94
I think I've figured it out. The fuses are fine, but I think my turbo timer cuts power compeltely to the radio when I turn off the car. Bah. Weird.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheezit »</TD></TR><TR><TD CLASS="quote">I think I've figured it out. The fuses are fine, but I think my turbo timer cuts power compeltely to the radio when I turn off the car. Bah. Weird.</TD></TR></TABLE> It shouldn't the constant power to the HU is not switched, you need to pull the HU and check the white/yellow or blue tracer wire for constant 12v+, [ power all the time, no matterif ign. is on or off or turbo timer is on or off] if it has power all the time, then the HU is "hooped"
94
PS Do you also lose radio pre sets?
94PS Do you also lose radio pre sets?
drgerry
Feb 1, 2013 10:57 PM
