Acura coded radio needs code every time?
Old Apr 12, 2005 | 05:26 AM
cheezit's Avatar
Default Acura coded radio needs code every time?
I put an old Acura tape deck in my car. It needed a code to turn on, as I know they do. But it asks for the code every time I turn on the car. Is this normal? Is there anything I can do to stop this? It isn't a big deal, just odd.
Old Apr 12, 2005 | 07:41 AM
fcm's Avatar
fcm
Old Fart
Default Re: Acura coded radio needs code every time? (cheezit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheezit &raquo;</TD></TR><TR><TD CLASS="quote">I put an old Acura tape deck in my car. It needed a code to turn on, as I know they do. But it asks for the code every time I turn on the car. Is this normal? Is there anything I can do to stop this? It isn't a big deal, just odd. </TD></TR></TABLE>It's only normal if there is no backup power, [constant] check the 7.5A fuse in the engine bay fuse box, do you also loose the radio presets? 94
Old Apr 12, 2005 | 07:57 AM
cheezit's Avatar
Default Re: Acura coded radio needs code every time? (fcm)
I think I've figured it out. The fuses are fine, but I think my turbo timer cuts power compeltely to the radio when I turn off the car. Bah. Weird.
Old Apr 13, 2005 | 07:58 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheezit &raquo;</TD></TR><TR><TD CLASS="quote">I think I've figured it out. The fuses are fine, but I think my turbo timer cuts power compeltely to the radio when I turn off the car. Bah. Weird.</TD></TR></TABLE> It shouldn't the constant power to the HU is not switched, you need to pull the HU and check the white/yellow or blue tracer wire for constant 12v+, [ power all the time, no matterif ign. is on or off or turbo timer is on or off] if it has power all the time, then the HU is "hooped" 94
PS Do you also lose radio pre sets?
drgerry
Feb 1, 2013 10:57 PM
radioblus
Jul 18, 2007 01:37 PM
markpaco
Jun 6, 2006 06:58 PM
purplehaze_gg
Jan 23, 2006 02:14 PM
INTEGDA6UK
Jul 20, 2004 01:14 PM
