radio code?
Old Jun 3, 2006 | 09:06 PM
markpaco's Avatar
Default radio code?
I lost the radio code for my R. If someone has access to the radio code database, please pm me. BTW, this is legit not stolen. Thanks!
Old Jun 3, 2006 | 09:18 PM
jetydosa's Avatar
25 Year Member
Default Re: radio code? (markpaco)
Check for a sticker on the bottom of your ashtray, or on the side of the inside of your glovebox.
Old Jun 3, 2006 | 09:20 PM
cxSHOE's Avatar
write down the serial # of the radio then call pflueger acura, 808-942-4555
Old Jun 3, 2006 | 09:40 PM
Kicker773's Avatar
Default Re: radio code? (cxSHOE)
it could also be located in your black planner notebook that came with the car if you got one. But best bet is to call the dealer, however it might require you to check the back of the radio which requires you to take it out.
Old Jun 3, 2006 | 11:40 PM
Typer#23's Avatar
Had this problem a couple months ago. Acura said it was 100 bucks for them to get it, But I was able to find it underneath the fuse box cover. I was told it is a dealer installed option. Did you check there?
Old Jun 4, 2006 | 07:32 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: radio code? (Typer#23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typer#23 &raquo;</TD></TR><TR><TD CLASS="quote">Acura said it was 100 bucks for them to get it</TD></TR></TABLE>
100 bucks for them to look a code up in a database?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typer#23 &raquo;</TD></TR><TR><TD CLASS="quote">I was told it is a dealer installed option.</TD></TR></TABLE>
You were told wrong (unless you're only referring to the part about writing the code on the fuse box cover). The coded radio was standard equipment in all G3 Integras.
Old Jun 4, 2006 | 07:43 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
so is there an actual known spot where it is written somewhere on the car, because I recently disconnected my battery for a steering wheel install and I cant call the dealer on a sunday to get my code #!!
Old Jun 4, 2006 | 07:44 AM
1GreyTeg's Avatar
Default Re: radio code? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
100 bucks for them to look a code up in a database?</TD></TR></TABLE>
Yes I'm sure you can't believe it but I've heard this multiple times.
Old Jun 4, 2006 | 07:48 AM
diversegsr's Avatar
Default Re: radio code? (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">Check for a sticker on the bottom of your ashtray, or on the side of the inside of your glovebox. </TD></TR></TABLE>
Old Jun 4, 2006 | 07:59 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Yes I'm sure you can't believe it but I've heard this multiple times.</TD></TR></TABLE>
I'm not doubting that it's true. But it still seems rather... what's the word... obscene.
My dealer's service department is happy to look up the security code on their customers' cars and provide it at no charge.
Old Jun 4, 2006 | 08:07 AM
1GreyTeg's Avatar
I'm not doubting that it's true. But it still seems rather... what's the word... obscene.</TD></TR></TABLE>
I know you weren't, I was ribbing you and completely agree. I can't remember how many times I've heard it over the years though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">My dealer's service department is happy to look up the security code on their customers' cars and provide it at no charge.
My first G3 integra was used and was missing the code as part of the owners manual but the selling dealer supplied the code free of charge.
My second and third G3's, first and second R's came with the radio code card as part of the owners handbook so no issue there.
I've also heard that on some Hondas that the code is even stickered to the top of the radio unit itself.
Some dealers will claim that you need to bring the car in for service and a tech needs to enter the code which is total BS. and Yes they will charge you for said service. Others will just charge a flat rate of $100. sometimes more or less to just look up the number in their database more total BS.
Old Jun 4, 2006 | 08:28 AM
Typer#23's Avatar
100 bucks is ridiculous, they said it was an hour of labor to do it which there rate is around 90 something bucks plus tax. My friend told me about the fuse box cause his code was also located there on his RL.
I was talking about the code being in the fuse box as a dealer installed option. Not the actual code.
Old Jun 4, 2006 | 08:38 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typer#23 &raquo;</TD></TR><TR><TD CLASS="quote">I was talking about the code being in the fuse box as a dealer installed option. Not the actual code.</TD></TR></TABLE>
"Dealer installed option" usually refers to optional equipment installed by the dealer, such as air conditioning on the '97-98 ITR. It's a stretch to refer to the dealer writing the code on the fuse box cover as a dealer installed option; that's like writing it there yourself and calling it an aftermarket modification.
Old Jun 4, 2006 | 08:48 AM
Kicker773's Avatar
As far as rate goes it varies from dealer to dealer, some dealers in chicago are charging 100 bucks, while some dealers in the burbs charge 80, for labor and getting the code for you. I'm not quiet sure about these options you guys mention about the code being at some particular places on the car, again i guess it varies but it doesn't hurt to check those locations that individuals have mentioned. However i would probably suggest to just get the radio out and get the serial number on the back of the radio and call it in to the dealer, i believe its free if you have the serial number of your radio (especially if its the dealer you purchased your car from). Its the labor that is charged by the dealer of takn the radio out, i dont think its the actual charge of lookn it up on their system, again it varies from dealer to dealer so you might have to call around if you do get the serial number from your radio. My best bet is try talkn to len and ask him what your options are. I believe the database is nationwide. Hope that helps, but sometimes askn nicely to a local dealer will be helpful
Old Jun 4, 2006 | 09:12 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: radio code? (Kicker773)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 &raquo;</TD></TR><TR><TD CLASS="quote">some dealers in chicago are charging 100 bucks, while some dealers in the burbs charge 80, for labor and getting the code for you.</TD></TR></TABLE>
There are no Acura dealers in the city of Chicago; all nine area dealers are in the suburbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 &raquo;</TD></TR><TR><TD CLASS="quote">i believe its free if you have the serial number of your radio (especially if its the dealer you purchased your car from). Its the labor that is charged by the dealer of takn the radio out, i dont think its the actual charge of lookn it up on their system</TD></TR></TABLE>
That's a much more sensible explanation of the $100 charge. And probably what service departments are accustomed to doing when a customer calls to say that they lost their code.
Kicker773's Avatar
well not actually in chicago(sorry i consider dealers less than an half hour away from me part of chicago)... but the one located or use to be located in niles i believe, on waukegan road was going to charge me 100 bucks for labor and the lookn it up for for free. The one in lisle was charging 80 for labor. Sadly but its true it does exist.
I dont really favor the one located in waukegan rd since they tried charging me 1k for a clutch install since according to them my clutch was the problem of my exhaust pipe noises.... did they really think i was that dumb to believe them.
Old Jun 4, 2006 | 03:00 PM
dc2r01's Avatar
the stock cd player blows .. id rather get a new pioneer deck for $100 !
Old Jun 5, 2006 | 10:01 PM
markpaco's Avatar
Default Re: (dc2r01)
Btw, here is the info on the deck:
Model #: 39100-ST7-A600
S/N: 97A501506
Ref#: CQ-JH9710A
Manf: Oct 2000
Maybe someone can look it up?
Old Jun 5, 2006 | 10:30 PM
Haleiwa-Brando's Avatar
Default Re: (markpaco)
Marc,
I've owned four DC2's. Every single factory deck that I have seen (counting my four owned) has had the code sticker stuck to the deck it's self. You will have to pull it to double check.
Nice anti-theft feature
Old Jun 6, 2006 | 08:44 AM
markpaco's Avatar
Default Re: (Haleiwa-Brando)
I checked both under the ashtray and all around the deck; nothing.
Old Jun 6, 2006 | 09:26 AM
YumVTEC's Avatar
the reason the dealer charges $100 is to pull the radio out of the car and look at the serial # on it. if you call any honda or acura dealer parts department with the serial # after you pull the radio yourself, they can look up the code on their computer in about 5 seconds. call different dealerships if you get hassled. i've never been asked for proof of ownership once when i call the two Acura dealers here in Utah for that.
Old Jun 6, 2006 | 06:58 PM
Echo7847's Avatar
Default Re: (YumVTEC)
Pm'd with your anti-theft code.
DipStick
Acura TL, RL & ZDX
Apr 7, 2011 11:51 AM
Adankid
Sep 19, 2008 02:52 PM
radioblus
Jul 18, 2007 01:37 PM
drrnbrow
Acura TL, RL & ZDX
Feb 19, 2007 03:52 AM
bLuEciVicGuY
Dec 2, 2004 09:26 AM
