HELP! Sister's EK running bad with swap
Hey guys. I'm posting on behalf of my sister. She has 00 ek. Her motor blew and she replaced the motor with a used one. The motor is running bad she says and has the check engine light on now. (I dont have a problem with check engine light racing but if it is sour then i do) anyway, she did the paperclip test thing and its the zero code. What is that exactly?
Thanks
Thanks
hmm..haynes book of god says this...
(1)
primary heated o2 sensor circuit low voltage...
or primary heated o2 sensor circuit high voltage...
(1)
jumper....i hadn't known she was using a jumper..i thought she threw the same engine she had in it...ethier way...same deal with obd1 and 2...
bjaeyang
19
Apr 7, 2003 05:28 PM
so...?
