OT: Converting kg/mm to lbs/inch
I'm looking around at spring and some are kg/mm and some are lbs/inch. Could somebody please tell me how to covert back and forth between the two so I can make some comparisons..
(I'll brush up on my math later)
Thanks...
Thanks...
Okay, math lesson:
1kg/mm * 25.4mm/1in * 2.2lb/1kg = 55.88 lb/in
1kg/mm * 25.4mm/1in * 2.20462262184878lb/1kg = 55.997414594959012 lb/in
Okay, math lesson:
Or, for those who need more precision:
would all the decimals after the 55 be accurate (irrelevant?) b/c the inch>mm conversion only has three significant numbers. *shrugs*
y
shi - who ain not math genius
y
y
y
CB
<U>Metric to Non-Metric:</U>
Millimeters x .03937 = Inches
http://anduin.eldar.org/~ben/convert/kgram_lb.html
Cool program...enter in and it automatically calculates for you.
That was officially decreed in the Weights and Measures Act of 1963. For more background and history of units of measuring length, click here.
[Modified by nsxtcjr, 4:22 PM 1/29/2002]
y
If thats the case then it should be 56. 55.88 rounds up to 56!
CB
y
CB
Actually, wouldnt it be 60 since the lowest value is 1
But 0s to the right arent significant
However, if the number is exact, then the zeros to the right are significant.
KillaB-
21
Oct 23, 2004 03:03 PM
gingboy
May 28, 2002 07:22 AM
