12+volt ground wire location
Old Apr 11, 2005 | 05:44 PM
85mm LS VTEC's Avatar
Default 12+volt ground wire location
What wires on the ecu wire harness are ground and 12+? I need the 12+ wire to supply the power only when the key is turned on, not be a constant supply. Thanks.
Old Apr 11, 2005 | 05:56 PM
SuperSteve737's Avatar
Run it off your fuse box instead, less chance of screwing something major up.
Old Apr 11, 2005 | 06:06 PM
Default Re: (SuperSteve737)
I need to hook up my PLX-300 and it says to wire it as close to the ecu as possible. Anyone else know what color wires these are?
Old Apr 11, 2005 | 06:46 PM
Rywire's Avatar
Default Re: (85mm LS VTEC)
Your 0-1 jumper (jkobd) has a +12 at the yel wire, and a ground at the purple.
Ryan
98civhatch
Jul 5, 2009 05:58 PM
EK k kay
Jul 8, 2006 08:25 PM
JDMlyfestyle
19
Feb 4, 2005 07:51 PM
buzzsawstan
Jun 30, 2004 09:09 PM
Trigun
Apr 18, 2002 03:26 AM
