Shaking problem when touching the brakes
Old Apr 11, 2005 | 05:29 PM
STN_Pat's Avatar
Default Shaking problem when touching the brakes
Heya !
Just finished installing the front and rear conversion on the hatch. Rear disc and front integra knukles with ITR redrilled to 4x100 rotors and ITR calipers. Had to use a 3mm spacer between the hub and the disc to make it fit.
Ok problem is that over 60 mph, when I hit the brake, the steering shakes a lot. It looks like rotors aren't straight.
Here are my hypothesis, do share how you see my problem :
1. The spacer makes the disc sits uneven on the hub.
Solution : Use a 3mm (machined) washer on each of the front studs (8 total). (edited : the spacer is already supposed to be 3mm and balanced.......)
2. The fact that the rotor isn't hubcentric with the non-itr knukle. (this has been considered when the machine shop redrilled the rotors and the space between the hub and the rotor looks pretty even (mesured but it is hard to be precise, even with a digital galiper).
Solution : Have some metal ring made; exterior diameter = to sit tapper into the itr disc and the interior diameter = to sit perfectly on the hub.
3. The rotor is simply uneven ? (It is a brand new Altrom Ultra 8 rotor, never installed).
This causes me serious headache. Any input will be appreciated
Patrick who's been scratching his head a lot lately
EDITED :
Forgot to add this :
- Hubs were both cleaned up so they're total flat
- Problem comes from the front (duh), when holding the handbrake as the same speed, it doesnt shake.
- lugs were torqued !
Modified by STN_Pat at 3:01 AM 4/12/2005
Old Apr 11, 2005 | 10:17 PM
slammed_93_hatch's Avatar
Default Re: Shaking problem when touching the brakes (STN_Pat)
are you sure there not hubcentric?
you could try the prelude 93 vtec rotor, that im almost 100% sure is hub centric.
Old Apr 11, 2005 | 10:35 PM
PURPLETERROR aka BIGMATT's Avatar
Use the prelude vtec rotor, they are hubcentric. I have had 0 .problems with mine
Old Apr 12, 2005 | 05:09 AM
STN_Pat's Avatar
Default Re: Shaking problem when touching the brakes (PURPLETERROR)
ITR rotor : 28$
Prelude vtec rotor : 67$
I'll have the current rotor "turned" by whom redrilled them. We'll see.
Modified by STN_Pat at 2:53 PM 4/12/2005
SlowB16
Sep 7, 2013 12:41 PM
555R
Oct 30, 2005 09:43 AM
miksew
Feb 6, 2004 01:23 PM
2fcknfst
Oct 8, 2001 06:02 PM
