How would I fix this?
» Search Results
Your search for snapped bolt returned 40 results.
» Search Results
Your search for stripped bolt returned 112 results.
» Search Results
Your search for broken bolt returned 85 results.
» Search Results
» Search Results
Slot it with a dremel and use a big screwdriver to unscrew it. You're lucky it broke up there and not down in the head like mine did. I just left the ****** there. So some oil gets out, who cares? Captain Planet can suck my dick.
take the valve cover off and replace that stud. get a new one from honda along with a new valve cover gasket. should take you all of 15 mins to fix.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowimport »</TD></TR><TR><TD CLASS="quote">take the valve cover off and replace that stud. get a new one from honda along with a new valve cover gasket. should take you all of 15 mins to fix.</TD></TR></TABLE>
Yup
You're lucky, the other SOHC valve covers are not studded and the bolts get broken in the head...which is a big PITA
Yup
there's a lot of way to do it:
1. like someone mentioned above... dremel a + groove and stick your screwdriver and poof!
2. get a vise grip and eureka!
3. not really necessary but drill through the center of the bolt... and use a reverse threaded easy out and kapoww youre done
4. take VC off, try to double nut it and remove
doood
Mar 26, 2012 06:54 PM
...emu...
12
May 8, 2005 07:02 PM
