GSR Brakes...gettin noises
Any real input would be helpful...
I recently did a four wheel disk brake conversion from a GSR (front and rear) and now im gettin rotational noises...i thought it may have been the rotor so i just had it resurfaced and its still making the noises...i put on some rotors that i knew were fine and still made noises....my alignment is off and when i turn left it kind of goes away...so if i got an alignment would i be fine or could it be the axle
.... thanks
.... thanks
new info...took off the wheel and started rotating the whole thing so the axle would move...while doing a full rotation i felt that at a certain spot it would be harder to spin...same spot every time...dunno what to do, either replace the axle or get a new wheel bearing
L2ILL
Oct 22, 2012 01:38 PM
method520
Mar 15, 2010 09:08 AM
