How can I test this injector (electric problem?)?
Old Apr 11, 2005 | 11:48 AM
Used2beAb16's Avatar
Default How can I test this injector (electric problem?)?
Ok, i made a post earlier without much luck. sooo
I am plagued with a problem, RSX-s with Jackson charger (7psi) and hondata k-pro, also running 550 cc injectors.
The car ran fine for a few months and a few thousand miles, then 1 day it hydrolocked itself with fuel.
It seems that the injectors are being held open, and im assuming that its electronical because the injectors were tested by after this happened.
I took out the plugs and injectors and it turns over fine, but whenever u hook everything up, after 20 seconds it just fills with fuel and locks up.
Is there some way to test the wires? maybe i should ask how the ecu works and how could it cause the injectors to stay open?
Old Apr 11, 2005 | 01:48 PM
fastcivicboy's Avatar
do you have anything controlling the injectors? Pull them out and get them tested or just throw other ones in and see if that fixes the problem.
Old Apr 11, 2005 | 01:49 PM
when you pulled the plugs how did they look?
Old Apr 11, 2005 | 08:18 PM
Default Re: (fastcivicboy)
Dude i had the injectors tested by Acura, and then by RC Engineering, and i had the computer checked by hondata, everything is OK. It has to be a stuck ground, or lack thereof or something holding the injectors open whenever its running.
TokuiAutowerks
Jun 19, 2008 06:02 PM
freakasis
Jan 11, 2006 03:43 PM
SPOOLINmatt
Jun 15, 2005 09:35 PM
grimald
Nov 26, 2004 04:38 PM
