rpm switch as vtec controller?
Old Apr 11, 2005 | 08:03 AM
Lewdin' Incognito's Avatar
Default rpm switch as vtec controller?
As the title says, I'm thinking of using an rpm switch to activate/deactivate my vtec solenoid. I found a small company that custom programs rpm switches to have 8 different settings ($50). Anybody have any good, bad, or otherwise luck with this?
I have an H23 w/H22 head. I am just completing the switch....waiting on a couple parts. I thought this might be a good way to bypass buying another ECU (p13).
I like the idea of having an adjustable vtec controller, but would it be better to go with the p13 + controller?
Old Apr 11, 2005 | 10:20 AM
turbo boost's Avatar
Default Re: rpm switch as vtec controller? (neoluder)
u should have a vtec ecu...4 the different fuel and ign maps when vtec comes on....but put it on a dyno and make sure its not lean....should be fine tho
Shoot5Hole84
Apr 17, 2010 10:20 PM
regal1975
13
Apr 13, 2007 06:00 PM
quicksol95
17
Mar 9, 2004 02:39 PM
Wazup
Aug 13, 2003 08:24 PM
CLICC916
Sep 20, 2001 11:06 PM
