crank pulley
Old Apr 10, 2005 | 11:02 PM
menappi's Avatar
Default crank pulley
yes i know its been covered a million times. so i read that by putting the car in 5th and stomping on the brake keeps it from moving. it didnt seem to work like that for me though. also they make a tool thats hex shaped to put in the pulley to keep it from turning..only..my pully from my a6 doesnt have a hex shape in there. its just round for the socket to go. so im gonna try to just put a screwdriver into the flywheel but i dont know where to put my big *** breaker bar so i can work it. i mean..unless i jacked my car up liek 5 feet, there no way i would be able to use it? maybe if i bought a like 3 foot extension..i doubt that would work though? how do u guys do it with a breaker bar. theres no room in the engine bay to maneuver the bar enough.
Old Apr 10, 2005 | 11:39 PM
thumbtack's Avatar
Default Re: crank pulley (menappi)
you jack the car up and lay on the ground pushing the breaker bar up towards the hood. Also try using a combination (box and open end) wrench and a bolt. Put the open end on the pressure plate of the flywheel and bolt it to the tranny housing.
Old Apr 11, 2005 | 01:05 AM
menappi's Avatar
i nkow about the wrench trick, but that can only be done with the tranny off though right? hrm if i pulled the breaker bar up towards the hood, then that would be tightening the bolt..?
Old Apr 11, 2005 | 07:27 AM
92integra_gs's Avatar
you need a chain wrench to counter the pulley going clockwise... have someone hold that and then with the breakerbar under the car ( take your engine mud guard (those plastic things)and i am assuming you got your car jack up)...once you get that bolt loose spray that baby up wid either WD-40 or PB catalyst penetrator.... remember there is a key so dont lose that....
Old Apr 11, 2005 | 07:36 AM
I8ayellowcrayon's Avatar
Mac makes an awesome tool for this. Its a "hand impact" power bar thing...
We just put two bolts in the pulley and put a 1/2"x4' steel bar between the two bolts and went crazy on the pulley bolt. We finally got it, I fell, the steel bar was bent, but we got it.
Old Apr 11, 2005 | 10:24 AM
menappi's Avatar
i still dont get how uhave enough room under the car to move the breaker bar. i have a 2 foot bar and a 3 foot pipe. there no way i will be able to get any leverage and already broke 2 12" breaker bars. i was thinking remove the driver side mount so i can get a full range of motion but there is a metal piece that is stuck to the block that wont come out.
Old Apr 11, 2005 | 10:37 AM
user 98292739's Avatar
i cant explain it...but ill post up pics on how i did it that only took 2 mins...and requires no taking off of anything cept for the wheel of course.
Old Apr 11, 2005 | 07:39 PM
menappi's Avatar
hey thanks ill be looking forward to those pics. i need to get this baby off.
Old Apr 12, 2005 | 07:05 PM
We just jacked the car up a little bit and put some jack stands under it.
Old Apr 12, 2005 | 08:22 PM
marlin's Avatar
Default Re: (I8ayellowcrayon)
Usually when I can't get a bolt loose, I heat it up with a propane torch. I picked one up from Walmart for $20. Heat it up and that usually breaks free some of that rust or loctite. I did that for the crank pulley but it didn't work. I tried a few of those other tricks and they didn't work.
Best thing you can do, is get yourself some air tools. I picked up a compressor and an impact wrench from Harbor Freight and in less than a minute that sucka was off. Awesome stuff and now you have an impact wrench!!!
Old Apr 12, 2005 | 08:32 PM
marlin's Avatar
Default Re: (marlin)
BTW, I had a 2 ft long breaker bar with a pipe with the car on jack stands and I was MOVING the car. Seriously, you're going to hurt yourself if you keep trying. Get the cheapo air compressor ($80) and spend a bit more on the wrench ($50).
Old Apr 12, 2005 | 11:35 PM
menappi's Avatar
i have a craftsman compressor and impact wrench. it didnt budge it.
Old Apr 13, 2005 | 06:21 AM
you have to have at least a 1000 lb torque wrench to get it off....cheapy impact wrenches wont even get my lugs off...
Old Apr 14, 2005 | 09:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marlin &raquo;</TD></TR><TR><TD CLASS="quote">BTW, I had a 2 ft long breaker bar with a pipe with the car on jack stands and I was MOVING the car. Seriously, you're going to hurt yourself if you keep trying. Get the cheapo air compressor ($80) and spend a bit more on the wrench ($50).
I tried my 150 psi compressor and Blue Point impact and the bolt wouldn't move for me. I don't think you had the E brake on, or the way you were using the jack stands was the correct way if the car was moving....
Old Apr 14, 2005 | 10:34 AM
the compressor has very little to do with it...its the impact wrench not having enough torque...
Old Apr 14, 2005 | 10:41 AM
menappi's Avatar
hey loco rex, when you did yours and it was on the jackstand..did you have the car in gear? or did the breaker bar in the hub prevetn it from moving? also how did you get any power with that giant extension, i know when using a long one its hard to get it to stay still while u pull on it.
driftam1
May 8, 2008 08:02 PM
projectjazzmine
Jan 20, 2007 08:55 PM
shauniewalnuts
19
Dec 25, 2004 11:33 AM
Bspec18
Nov 15, 2003 01:11 AM
Flamenco-T
Jul 8, 2002 05:53 PM
