Mini-Me making a funny noise.
Old Apr 10, 2005 | 08:31 PM
91_CRX's Avatar
Default Mini-Me making a funny noise. Need some help.
Ive got a 96 y8 head with brand new head gasket, intake manifold gasket. Factory head bolts. Vtec solenoid is NOT hooked up. Running of a A6 intake manifold and A6 distributor. Y8 timing belt.
Its making a wierd noise as if something were inside my engine. If you knew how one of those vaccum cleaners that are the "vortech" and put a BB inside it, it sounds like that.
I hear the sound from start up all the way to 6.5k rpm. Im afraid to drive it. I have not took the valve cover off to check it. Although its not 100% constant, it is mainly when the throttle is opened wide really fast. A very very slow rev it wont make the noise. Sound comes from around the left side.
Im getting the head work done from a guy I know locally and he owns a "shop". He said he test drove it and it didnt make the noise but when I got it, it made the noise. Hes going to check it out and see what it is, but im wondering if anyone knows what it is because I have the car for a little bit.
any help is appreciated
Old Apr 10, 2005 | 11:04 PM
96-EJ6 B18C's Avatar
Default Re: Mini-Me making a funny noise. Need some help. (91_CRX)
Valve lash out of spec??? Detonation??? Just some ideas.
Old Apr 11, 2005 | 08:08 AM
orangecivic89's Avatar
Default Re: Mini-Me making a funny noise. Need some help. (96-EJ6 B18C)
it is most likely detonation because that is a high compression setup if you dont have high enough octane or if timing is out a hair you would probably get detonation
Old Apr 20, 2005 | 03:03 PM
91_CRX's Avatar
Default Re: Mini-Me making a funny noise. Need some help. (orangecivic89)
Still need help on this! BUMP. All the valve clearances are up to spec, correct timing, doesnt see any pully wobble or tensioner problems, just this weird noise at WOT.
also my gf said she saw smoke and it smelled like gas when i sped up past her.
Any ideas?!
Old Apr 20, 2005 | 03:59 PM
senpai's Avatar
adjustable cam gear?
14
Sep 19, 2010 04:57 PM
JOS-EM1
26
Dec 29, 2009 06:26 AM
98coupeek
Nov 24, 2009 08:15 AM
rare_db2
Jul 7, 2007 08:11 PM
RacinMasonC
Jun 26, 2003 08:32 AM
