I need help ASAP,b16a woos!!! (help me solve this problem!)
Old Apr 10, 2005 | 07:40 PM
gtarwiz's Avatar
Default I need help ASAP,b16a woos!!! (help me solve this problem!)
Ok, here it is!!!! My long awaited b16a!!! This is the engine of my dreams since I first got my car!!! I bought it, its in my car, its wired, it idles great but bogs like a bitch when any gas is put to it!!! We have done compression tests to it and its 210 across the board so there is definately compression in each of the cylanders. This is a b16a1 motor. It was converted from obd-1 to obd-0 with a makeshift harness. We have 440 injectors in it right now and its way to much fuel for it. We know that the troubles are coming from the fuel, so heres my question, what OBD-0 injectors can be used for a stock b16a1 motor? I just want my baby back!!!! This is such a torture just seeing my car run but not run at the same time!!!! plz, i need help ASAP!!!!
Old Apr 10, 2005 | 07:56 PM
gtarwiz's Avatar
Default Re: I need help ASAP,b16a woos!!! (gtarwiz)
BUMP, PLZ HELP ME!!!
Old Apr 10, 2005 | 08:03 PM
lodo1's Avatar
well, any stock obd0 injectors will work, as they are all 240cc's. as for the bogging itself, i would check the timing
Old Apr 10, 2005 | 08:04 PM
gtarwiz's Avatar
Default Re: I need help ASAP,b16a woos!!! (tdocrx)
i no that I need stock 240 injectors but for what car exactly?
Old Apr 10, 2005 | 08:17 PM
str8boost's Avatar
i have a set of 270 rc injectors obdo, not in use , only 1k in them.. email if interested..
Old Apr 10, 2005 | 08:23 PM
gtarwiz's Avatar
Default Re: (str8boost)
im just trying to buy some stock injectors from autozone or some place like that but I dont know what car I need to get them from, so If someone could please enlighten me, that would be incredible! I think I need to get integra ones but I want to be sure and I need to know exactly what year I can get it from
Old Apr 10, 2005 | 08:25 PM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtarwiz &raquo;</TD></TR><TR><TD CLASS="quote">i no that I need stock 240 injectors but for what car exactly?</TD></TR></TABLE>
88-91 civic/crx
88-91 integra
Should be easy enough to find.
Old Apr 10, 2005 | 08:28 PM
gtarwiz's Avatar
Default Re: I need help ASAP,b16a woos!!! (91civic)
now ur absolutly positive they will work?
Old Apr 10, 2005 | 08:31 PM
EP3_05's Avatar
Yes the honda injectors I mentioned will work because they are peak and hold and OBD0. Theoretically any honda injector would work as long as you have the correct injector clips and add or remove the injector resistor box depending on if the injectors are peak and hold or saturated. DSM 450cc injectors bolt into honda fuel rails if you bore the seals out a bit.
Old Apr 10, 2005 | 08:43 PM
gtarwiz's Avatar
cool cool cool!!!!! that is exactly what I needed to hear!!! And that is what needs to be fixed so hopefully the car will be running tomorrow!
Old Apr 11, 2005 | 06:48 PM
gtarwiz's Avatar
NEW PROBLEM!!!!! We bought the new stock injectors and damn were they expensive!! But anyway, When I shift the car, the it can seem to find the proper gear!!! I have Avid Racing shift linkages with a DC Sports short shifter. We think that it is the bushing that needs to go with the shift linkage but it didnt come with one and the stock one was to small!!! So does anyone know where I can find this bushing? Cuz when it takes me 10 minutes to find reverse, it makes me a little worried. And when its in first, if the shifter is hit or touched at all, it pops out of gear all together!!! So I need anyone and Everyones advice!!!!!!!
Old Apr 11, 2005 | 07:19 PM
gtarwiz's Avatar
!!!!!!!!!!!!!!!!!!!!!!BUMP THIS ****!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!BUMP THIS ****!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 11, 2005 | 10:19 PM
lodo1's Avatar
you can get the energy suspension bushings for like 15 bucks
seanevo3
Jul 29, 2017 02:24 AM
1 sicK gtR33
Mar 24, 2010 11:11 PM
the.hamburglar
Mar 11, 2006 06:10 PM
ldanphanl
Mar 15, 2005 04:06 PM
