98 itr engine into a 97civic. electrical load question... did a search....
Old Apr 10, 2005 | 06:59 PM
thejdmkid's Avatar
Default 98 itr engine into a 97civic. electrical load question... did a search....
I just finished doing a swap into a 97 civic dx, I used a 96-98 civic ex harness. The engine is a 98 jdm itr. The problem we are having is when the A/C is turned on, at idle the rpm drop down to between 200/500 rpm and the engine shakes like crazy. I figured it was the electrical load sensor was not reading, but then I remembered that the jdm p73 has a different pin out for the electrical load sensor. Does anyone know what pin I'm supposed to switch from the harness to make the ecu read the sensor?
thanks
Old Apr 11, 2005 | 06:59 PM
thejdmkid's Avatar
Default Re: 98 itr engine into a 97civic. electrical load question... did a search.... (thejdmkid)
anyone?
Old Apr 12, 2005 | 12:54 PM
thejdmkid's Avatar
guess not?
Old Apr 13, 2005 | 07:39 PM
thejdmkid's Avatar
Can anyone confirm if the p73 from any year has an electrical load detector.
Old Apr 19, 2005 | 06:23 PM
thejdmkid's Avatar
anyone with a pin out for the ecu of any 96-up integra i think they should all have the electrical load detector in the same pin location.
thanks
silk106
Sep 17, 2010 04:56 PM
VargasCTR98
Mar 28, 2007 02:34 PM
Hybrid-Fusion
Dec 3, 2005 09:46 AM
GQ Cowboy
Jan 24, 2002 07:47 AM
