D16Z6 or D15 VTEC
I got very little hits on the search for a direct comparison of these two motors.
I have a stock crx dx (non vtec), and want to buy a vtec engine and rebuild it solid. Pretty much new everything, and then turbo it.
Does the .1 liter affect much
? theres a good $300 price difference in the engines. Which is more solid for a FI application and which is better for upgrading? From what little I could find, it seems the z6 is easier to upgrade.
Any input would be appreciated
? theres a good $300 price difference in the engines. Which is more solid for a FI application and which is better for upgrading? From what little I could find, it seems the z6 is easier to upgrade.Any input would be appreciated
how much can you get a z6 vs d15 for? id say go for the better price/lower milage. whatever seems like the better deal, they are pretty similar. however d16z6 will probably have more aftmkt parts avail, but then again they are most likely interchangeable
https://honda-tech.com/zerothread?id=1106447
https://honda-tech.com/zerothread?id=1024868
Your search for d15b returned 201 results
Your search for d16z6 returned 224 results.
i meant to add that you might have to search each one individually and compare them like that. there weren't many threads comparing the two. i've got a z6 that i just killed and replaced it with a z6.
rebuilding the z6 would be cheaper, since the d15b pistons have a unique offset. the d15b has a more aggressive cam and a little more compression so it does not lose any power to the z6.
d16z6 would probly be best. but a Z6 bottom end with a d15b head would work awesome. It might even up your compression. Im not to sure. Theres diffrent combos you can do to get a better motor. But if your rebuilding I would rebuild the d16z6 with diffrent pistons to up the compression. More compression=More Power.
BUT a d15 will have a lower rod\crank ratio. Witch will mean higher revs.
