Getting rid of shifter slop part II
Old Apr 10, 2005 | 06:11 PM
eluder33's Avatar
Default Getting rid of shifter slop part II
I'm trying to get rid of all the slop in my shift and have replace the base plate bushings with washers and I'm going to tackle the shifter's ball bushings and sideplate bushings part #6 and 9 (the yellow flat ones), to try and rid the slop since I can't afford the 4 bidden shifter I'm gonna get a new one of these from honda and let everyone know how it goes.
here is my first write up.
https://honda-tech.com/zerothread?id=1153749
what else can wear out on these things?
Old Apr 10, 2005 | 06:58 PM
high_revs's Avatar
where does that **** go? lol....i sip tied my cable ends where it connects to the actual shifter and i have minimal play...i love how it feels now....zip ties
Old Apr 11, 2005 | 05:33 AM
vtec_lude's Avatar
so you tied the 2 cables tighter together near the shifter? does this work? I'm thinking when you shifter it from left to right the zip tie will get loose and then tight again? if you get what i mean....
Old Apr 11, 2005 | 05:34 AM
vtec_lude's Avatar
btw matty c let us know how this works... i guess it means your taking the shifter apart? some pics would be nice....
The part one of your mod was great... will be looking forward to how part 2 turns out!!
Old Apr 11, 2005 | 07:43 AM
eluder33's Avatar
Default Re: (vtec_lude)
I'm getting ready to order the parts anything else I should get that can wear out?
Old Apr 11, 2005 | 11:17 AM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_lude &raquo;</TD></TR><TR><TD CLASS="quote">so you tied the 2 cables tighter together near the shifter? does this work? I'm thinking when you shifter it from left to right the zip tie will get loose and then tight again? if you get what i mean....</TD></TR></TABLE>
nahh i cant explain it....i'll try to get pics.
Old Apr 11, 2005 | 01:45 PM
C M S's Avatar
Default Re: (h23 killa)
I know what u meen when u say slop, but trust me save th e money a buy the shifter. THre isnt much u can do for a lude shifter. I bought the 4 bidden unit, let me tell u it is night and day....
Old Apr 11, 2005 | 03:49 PM
high_revs's Avatar
Default Re: (1SICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM &raquo;</TD></TR><TR><TD CLASS="quote"> I know what u meen when u say slop, but trust me save th e money a buy the shifter. THre isnt much u can do for a lude shifter. I bought the 4 bidden unit, let me tell u it is night and day....</TD></TR></TABLE>
you wouldnt say that if you shifted in my car....i made a custom shifter....i cut the shifter down and welded a new bolt with the right threads for the ****....not only does it sit low but the throws are supser short, and guess what...it was free....im sure the 4bidden one is great....a friend of mine has 1....i will have a comparrison when i get to feel it..
Old Apr 11, 2005 | 08:13 PM
eluder33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23 killa &raquo;</TD></TR><TR><TD CLASS="quote">
you wouldnt say that if you shifted in my car....i made a custom shifter....i cut the shifter down and welded a new bolt with the right threads for the ****....not only does it sit low but the throws are supser short, and guess what...it was free....im sure the 4bidden one is great....a friend of mine has 1....i will have a comparrison when i get to feel it..</TD></TR></TABLE>
you got pics of that??
Old Apr 12, 2005 | 02:08 PM
high_revs's Avatar
Default Re: (matty c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matty c &raquo;</TD></TR><TR><TD CLASS="quote">
you got pics of that??</TD></TR></TABLE>
im gonna try to get them tonight....but no promises..
Old Apr 12, 2005 | 03:38 PM
jackstands's Avatar
There's a rubber bushing where shifter cable connects to the shifter. Replace that with a metal bushing or a needle bearing. I used a needle bearing with my 4bidden shifter. Most of the slop is gone. Just gotta find metal pieces to replace my shifter plate bushings.
Old Apr 12, 2005 | 03:41 PM
4bidden's Avatar
Default Re: (jackstands)
That might VERY slightly reduce the front/back but unless your stock bolt was really worn or something (not likely), it shouldnt have made much of a difference at all.
Most of the "slop" comes from the square piece that goes in the bracket on the left side. The ball portion of my shifter is designed a tad larger than stock to fit tighter inside that square pressure fit piece to try and reduce slop as much as possible.
Old Apr 12, 2005 | 04:45 PM
AdReNaLiN's Avatar
I would like to see where the zip ties go?
Old Apr 12, 2005 | 05:14 PM
high_revs's Avatar
Default Re: (AdReNaLiN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdReNaLiN &raquo;</TD></TR><TR><TD CLASS="quote">I would like to see where the zip ties go?</TD></TR></TABLE>
i put the zip ties where the cable connects to the shifter....so it puts pressure on the cable against the shifter and basically wont let it "play" so much and reduces most of the slop.... i love the way my shifter feels compared to my friends shifter in his DC2
Old Apr 12, 2005 | 07:54 PM
budget's Avatar
does all of this only work in 4th gens or can it be done in 5th gens?
-4bidden shifter avail for 5th gens?
-zip tie set up, can i do it for a 5th gen?
Old Apr 13, 2005 | 04:55 AM
95greenlude's Avatar
Default Re: (ratboy)
^^^ answer to #1
NO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23 killa &raquo;</TD></TR><TR><TD CLASS="quote">i put the zip ties where the cable connects to the shifter....so it puts pressure on the cable against the shifter and basically wont let it "play" so much and reduces most of the slop.... i love the way my shifter feels compared to my friends shifter in his DC2</TD></TR></TABLE>
you are right and wrong in the same sentance
go Here and read Shakes post almost to the bottom of the page and learn how to zip-tie your cables properly
Old Apr 13, 2005 | 09:29 AM
high_revs's Avatar
Default Re: (95greenlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude &raquo;</TD></TR><TR><TD CLASS="quote">^^^ answer to #1
NO
go Here and read Shakes post almost to the bottom of the page and learn how to zip-tie your cables properly </TD></TR></TABLE>
we are talking about shifter slop not tying the cables together...two totally different things my friend
Old Apr 13, 2005 | 11:52 AM
eh...its all the same thing
Old Apr 13, 2005 | 05:25 PM
high_revs's Avatar
it's related lol
masospaghetti
Sep 9, 2014 03:56 PM
BDM
Sep 24, 2009 02:16 AM
DOUBLExDEUCEx22
Jul 8, 2009 02:12 PM
turbotime
May 4, 2006 10:15 PM
eluder33
Nov 20, 2004 03:05 PM
