braking/suspension problem
sup guys, i drive a 00 si
my front right side suspension squeaks when u push down on it from outside
and it squeaks whenever i go over any kind of bump ..
also, my front right brake makes creaking sounds
i dont know whats wrong with it, i just replaced all my brake pads ..
maybe i have a messed up rotor ?
could these two problems be related ?
i dont have access to a jack right now so i couldnt check it out ..
im a nub so any info is appreciated ..
I would think bushing problems. My car does the same thing when I drive it. WHat i recommend is to jack it up and check every rubber bushing make sure nothing looks out of the norm
Do you have OEM bushings? Squeaking is usually caused by polyurethane bushings not being lubed enough when installed. Also, check to see if there is any oil residue on the strut itself. That'll indicate if it's blown or not. When you press down on the car from the outside, does it bounce more than it should?
it doesnt seem to bounce any more so i dont think its the strut itself ..
could it just be messed up bushings ?
i know my upper control arm bushings are shot, but would that cause squeaking sounds ?
the sounds are isolated to my front right ..
also, what could be causing the creaking sounds from my brakes ?
thanks for all the input so far
94maroonturbocp
Oct 23, 2003 03:18 PM
hugh_jazz_sponer
Sep 30, 2003 06:34 PM
