$100 is gonna satrt my turbo setup
Old Jan 29, 2002 | 12:00 AM
Charles B.'s Avatar
Default $100 is gonna satrt my turbo setup
For that much I'm getting a 2nd-gen Eclipse turbo, a B-series turbo manifold, and a downpipe. This I plan to run on my GSR hatch. I'm getting this from a friend so everything is okay and legit. I was just wondering what is the turbo in the 2nd-gen Eclipse and who has used it or is using it. I am also plannnig to plug the external wastegate and just run the internal wastegate. Is that a good idea? I'd get an external WG but I'm on a budget. Any feedback on my setup is appreciated.
Old Jan 29, 2002 | 12:07 AM
LsTurbo91's Avatar
Default Re: $100 is gonna satrt my turbo setup (SuperDuperEG)
that'll work, the 2nd gen came with a t25 turbo.
Old Jan 29, 2002 | 05:56 AM
RGAZ's Avatar
New User
The T25 is a little small but you will love the spool time, almost instant.
Check the site in my sig if you want a bit more info.
Randy
Old Jan 29, 2002 | 03:46 PM
jabroni95gsr's Avatar
Default Re: $100 is gonna satrt my turbo setup (RGAZ)
RGAZ - or others who know. if i am trying to build a custom kit using the same T25 turbo do i absolutely NEED to have an intercooler? I only want to boost like 5lbs or so. nothing big. I noticed that on your website you built a turbo setup pretty cheap, was the intercooler necessary? I know some say no if you don't plan on getting crazy.,..,
thanks
Old Jan 29, 2002 | 05:16 PM
wickedxboi's Avatar
Default Re: $100 is gonna satrt my turbo setup (jabroni95gsr)
what size of a turbo came off a 92 eclipse?
Old Jan 29, 2002 | 05:17 PM
JCushing's Avatar
Default Re: $100 is gonna satrt my turbo setup (wickedxboi)
a mitsu 14g bigger than a t25 but smaller than a t3
Old Jan 29, 2002 | 05:30 PM
dbman96's Avatar
New User
RGAZ - ...do i absolutely NEED to have an intercooler? ...
Nah... I ran without an IC for awhile at around 6 psi or so. However I had some weird results with it; around VTEC crossover it would get completely gutless; I think maybe the VTEC ecus are very aggressive about the intake air temperature. But you can ALWAYS run without an IC and add one later. To be perfectly fair I had fuel management problems as well so the lack of IC may not have been THE problem, but when I put my IC on things got a lot better.
Old Jan 29, 2002 | 05:34 PM
gcajnr21's Avatar
where are you getting your manifold to fit the t25 turbo? i am looking for a cheap one right now.
Old Jan 29, 2002 | 05:55 PM
AbaZ's Avatar
Default Re: $100 is gonna satrt my turbo setup (JCushing)
A TDO5h aka (14b) on the 1g DSM's is actually a fairly large turbo. it is bigger then most T-3 turbos on factory cars... not including (T-bird/GN) But alot bigger then the Saab/Volvo/Nissan T-3 turbos. The t-25 turbo on the 2g DSM is a pretty small turbo, much like the small T-3 turbos. It spools very fast, even on a stock D-series motor.
A GSR with a 14b turbo should work pretty well together, hardly any lag at all. I have lots of friends with DSM's pushing 18psi on these turbos.. They pull pretty hard.
I am currently using a 14b on my Mini-me setup. Check out my page
Jeff Frank
akdrag
Jul 6, 2009 07:27 PM
2mchbst
Dec 30, 2008 05:22 AM
honda3x23
Jan 24, 2006 03:18 PM
skellator_thoj
Jan 22, 2003 02:48 PM
RiceBurner98SC
Jan 11, 2003 01:40 PM
