ECM not grounding grn/blk wire at A12/A14?
Old Apr 10, 2005 | 12:07 PM
xci_ed6's Avatar
Default ECM not grounding grn/blk wire at A12/A14?
I know it is a harness problem since every ECM i have tried does it only in this car.
Thermostat ground is on, I'm testing at the ECM pin.
ideas?
Old Apr 10, 2005 | 01:59 PM
doublethink's Avatar
Default Re: ECM not grounding grn/blk wire at A12/A14? (krustindumm)
the ground for the main relay also shares with clip A on the ecu if im not mistaken, make sure the ground to the right of the steering cloumn, above the radio, and the one by the hood release are hooked up.
also make sure the negative terminal to the battery goes directly to the block, as well as the chassis.
if all else fails just run a nice new ground.
Old Apr 11, 2005 | 12:50 PM
Keith P's Avatar
Default Re: ECM not grounding grn/blk wire at A12/A14? (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">if all else fails just run a nice new ground. </TD></TR></TABLE>
I had the same problem, and I ended up just splicing the wires near the ECU and grounding them
Old Apr 11, 2005 | 04:40 PM
xci_ed6's Avatar
Default Re: ECM not grounding grn/blk wire at A12/A14? (Keith P)
tried it now its not grounding the injectors
Old Apr 12, 2005 | 04:09 PM
xci_ed6's Avatar
bypassed the injector resistor box, still no pulse on my NOID light at the injectors, wires go to the right place, distributor wires go to the right place, tried a couple different ECM's, all of them work in another car. Checked all grounds in the system. Can get the car to run on starting fluid, no CEL.
Old Apr 12, 2005 | 05:15 PM
thug lyph's Avatar
this car is pissing me off, it's making me want to sell it and start over with a whole new brand of car
Coopa B18c5
May 6, 2013 02:09 PM
EK k kay
Jul 8, 2006 08:25 PM
( o )( o )
Apr 15, 2006 11:09 PM
shivern
Audio / Security / Video
Jan 3, 2005 09:18 AM
2ndgentegracer
Dec 14, 2004 06:49 PM
