LSD--need HELP!!!
Old Apr 10, 2005 | 10:47 AM
jdm_23_eg6's Avatar
Default LSD--need HELP!!!
hav a JDM Y21 (B16) HYDRAULIC TRANNY...im lookin into buyin a 2000 JDM OEM ITR LSD!!! the ITR LSD doesnt come w/ final drive nor bearing...
my questions are:
1.)would the ITR LSD fit on my JDM Y21 tranny?
2.)can i use the final drive and bearing on my JDM Y21 to bolt on to the ITR LSD?
3.)IF THE LSD DONT FIT, which oem lsd would i need for my JDM Y21
tranny?
4.)IF THE LSD DOES fit but needs a different final drive and bearing, which
final drive and bearing do i need?
5.)is their any other parts, modification or procedure i need to install the lsd?
ANY ADVISE, COMMENTS, SUGGESTION OR OPINION IS WELCOME!!!
and yes ive searched already and i only found 1 thread about it but wasnt really as helpfull!!!
this is the thread:
https://honda-tech.com/zerothread?id=1160661
Old Apr 10, 2005 | 02:20 PM
jdm_23_eg6's Avatar
Default Re: LSD--need HELP!!! (jdm_23_eg6)
help...
Old Apr 11, 2005 | 12:03 PM
jdm_23_eg6's Avatar
sum1 has to know this...
Old Apr 11, 2005 | 09:42 PM
jdm_23_eg6's Avatar
come on...any1?
Old Apr 12, 2005 | 11:55 AM
jdm_23_eg6's Avatar
itr lsd
Old Apr 12, 2005 | 02:59 PM
95lstegman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_23_eg6 &raquo;</TD></TR><TR><TD CLASS="quote">my questions are:
tranny?
5.)is their any other parts, modification or procedure i need to install the lsd?</TD></TR></TABLE>
1) yes, it will physically fit with the changing of 2 other parts
2) you CAN use the bearings from you tranny, but shouldn't EVER. and you'll need to change the ring gear and countershaft to a GS-R or ITR 4.40 set. those two parts only need to be changed.
3) ITR, CTR, SiR-G, etc. basically any OEM hydro B-series LSD are all the same, and require the same parts stated in 2)
4) already been there
5) already been there
pau-pau1
Transmission & Drivetrain
Mar 11, 2014 07:55 PM
Er4sEr
Sep 7, 2007 12:02 PM
Baron55
Aug 23, 2006 04:01 PM
vti444
Jun 20, 2005 03:33 PM
jdm_23_eg6
Apr 12, 2005 11:55 AM
