14b compressor on a wrx turbo
I asked that same question a while back, as I wanted something easy, that wouldn't require too much management. The short answer ended up being, No. It would require machining, a new shaft, and too much effort for the return. If you have a WRX, you should talk to Deadbolt turbo, on NASIOC.
HTH
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporty240 »</TD></TR><TR><TD CLASS="quote">Hey is it possible put a 14b compressor housing and wheel on a TD04L -13G(WRX turbo)? Will it bolt on or is it more trouble than its worth?</TD></TR></TABLE>
It is a lot of trouble and not at all worth it. The compressor cover of a td04 is not the same as that of a td05. The wheels and shafts are also sized diffently so it will require expensive machining. You would be better off getting a new turbo or a new cartridge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">more importantly isnt that turbine just tiny? I would never (again) put anything smaller than std T3 turbine on any honda engine.</TD></TR></TABLE>
I like my 14b since it has fast spool up and it's good as daliy car..very good 2000rpm- 6700rpm power....
scttydb411
Mar 24, 2004 10:09 PM
